Factory Tach missing plug?
Old Sep 29, 2015 | 07:41 PM
Lucille1986's Avatar
Lucille1986
Maytag, I just went back out with a flashlight and looked again. I cant find the other half. I'm just thinking someone must have modified something, somewhere, at sometime!
Thanks!
Old Sep 30, 2015 | 02:02 AM
Ken Blythen's Avatar
Ken Blythen
Not all trucks were 'plug & play' ready; there are a few instances of this that come up in searches.
My F250 (also an 83) was like this too, even though it had a gauge cluster.
I ran one wire from the coil to the donor tach, & another from a key-on live point for power.
Old Sep 30, 2015 | 06:09 AM
Lucille1986
Thanks Ken, I will just wire up.
Old Sep 30, 2015 | 02:30 PM
maytag906's Avatar
maytag906
If you wire it direct, is there a possibility of feedback, through the wire harness? Or are you just going to run a wire from the coil?
Old Sep 30, 2015 | 04:15 PM
Lucille1986
I have seen many instructions on the forum on how to wire the tach direct.
I was planning on pulling the circuit board/isolate the circuit board from the tach bolts as I have no idea if having the circuit board touching would cause gremlins or melt something.
Old Oct 9, 2015 | 10:15 AM
Lucille1986
I went to the junk yard today and found a truck with both ends of the under hood tachometer plug. I removed the female end and took it home with me.
On my truck I began to unwind electrical tape from the same area of harness I had removed the donor plug from. Guess what I found? A green and a black wire that had been cut. Donor plug is installed and I have a working tachometer.
Old Oct 9, 2015 | 12:33 PM
ctubutis's Avatar
ctubutis
Originally Posted by Lucille1986
...I began to unwind electrical tape from the same area of harness I had removed the donor plug from. Guess what I found?.
I've been wondering if it wasn't going to work out that way... thanks for the update.
Old Oct 9, 2015 | 08:50 PM
maytag906's Avatar
maytag906
Excellent! Glad you figured it out!
Israelx7
Nov 29, 2013 08:51 AM
Ethan9
Mar 24, 2008 06:19 PM
NateDog07
Apr 17, 2006 08:28 PM
turdbird
Electrical Systems/Wiring
Dec 3, 2005 03:52 PM
mooney456
Jul 4, 2004 11:41 AM
