Tach hookup
Old Mar 24, 2008 | 03:24 PM
Ethan9's Avatar
Ethan9
Tach hookup
I have a 92 F-150 with a 302 and am trying to hook up a Sun Super Tach 2 in it. It has a black wire which is obviously ground, and a red and white wire tied together with a blade on the end which looks like it fits in the fuse panel. Is this right? Which fuse should it plug into? It also has a green wire that needs to go to the ignition, but I have no idea where. Help!!!
Old Mar 24, 2008 | 03:29 PM
Nitramjr's Avatar
Nitramjr
It's been a couple years since I hooked mine up but in the Sun ST II that I have, the wires are for ground, ignition, power and backlight. The power and backlight can be wired together as yours appears to be. Just hook those to any KEYED 12v power. It doesn't have to be at the fuse panel but it should be. The ground can be anywhere. The ignition wire goes to the TACH plug on the wires that go into the distributor. It should be marked as such.
If you want your backlight to dim with your dashlights, separate the two wires and wire the white (?) wire to the headlight switch.
Good luck.
Old Mar 24, 2008 | 03:54 PM
Ethan9's Avatar
Ethan9
Thanks. I looked and I dont have a plug labeled TACH. Maybe it is because this truck did not come with one. Is there any wire that I could splice it to? Someone told me the negative side of the coil. There are two wires coming out of the coil, one red and one yellow.
Old Mar 24, 2008 | 05:57 PM
Nitramjr's Avatar
Nitramjr
Even though your truck didn't have a tach originally, the plug should have a tach signal plug. There should be a plug going into the distributor and one of the slots should be open - molded on the plastic should be the word TACH. There probably isn't a wire there already. Clean off the plug and take another look. I'd go out and take a pic of mine but it is too dark already.
Old Mar 24, 2008 | 06:03 PM
Virto's Avatar
Virto
I think you wire it to the tach signal coming right off the coil.
EDIT: Yep - right on the coil should be a tach test label.
Old Mar 24, 2008 | 06:19 PM
Nitramjr's Avatar
Nitramjr
Virto is probably right - it has been a couple years since I did mine and being that it is a long walk to the driveway, I may have given you bad info. Somewhere under the damned hood is a plug marked tach.....find it and you're in business.
By the way, it is worth the extra work to hook the backlight up to the dimmer rheostat in your headlight switch.
Handegard
Feb 22, 2014 11:27 AM
charles jones
Jan 7, 2006 07:59 PM
Zebich
Feb 20, 2005 10:20 PM
Nightrain
Dec 24, 2004 10:01 AM
mshumack
Oct 18, 2002 08:02 PM
