Factory Tach missing plug?
Old Sep 28, 2015 | 07:24 AM
Lucille1986's Avatar
Lucille1986
Hi folks, I have a 1983 F150 302 with a factory tach. The plug from the harness, green wire/black wire is there but unplugged. Where or what does it plug in to?
Thanks!
Old Sep 28, 2015 | 08:40 AM
Franklin2's Avatar
Franklin2
Find the green/black wire that goes from the ignition module box to the coil plug-in. Somewhere along there is where it plugs in.
Old Sep 28, 2015 | 08:56 AM
Lucille1986
Here is the plug. Green wire with yellow dots and a black wire. I am assuming this is the correct tach plug? Cant find anything to plug to.
Old Sep 28, 2015 | 09:03 AM
Franklin2's Avatar
Franklin2
Look up at the firewall, it comes out of a harness that goes through the firewall so it ends up at the instrument cluster.
Old Sep 28, 2015 | 09:48 AM
Lucille1986
There is no corresponding plug to plug in to. I researched the heck out of this forum for days and can"t find an answer. Just frustrated now. I'm missing something in this whole process.
1983 F150 302
Old Sep 28, 2015 | 04:06 PM
Franklin2's Avatar
Franklin2
Did this truck originally have a gauges in the cluster or just idiot lights?
Old Sep 28, 2015 | 05:25 PM
Lucille1986
I don't know. Previous owner was a 92 year old man who owned it since 85. I recently acquired the truck. All the other gauges work. The speedometer has a date stamp from 1983 which would lead me to believe the cluster is probably original?
Old Sep 29, 2015 | 07:32 AM
Franklin2's Avatar
Franklin2
All the cluster swap threads say you just plug it in and go, the wiring should already be there from the coil minus to the tach. So I don't know what your problem would be, unless the tach is faulty. The coil gets power anytime the key is in start or run, and the ignition module grounds and ungrounds the negative of the coil to make it fire. The tach simply takes this ground/unground signal and does a little math in the circuitry to give you rpm.
Old Sep 29, 2015 | 07:43 AM
Lucille1986
From all of the reading I have done on this site, I am in agreement with everything you've said. Maybe the tach is broken (I have tried 2), but where my confusion lies at this point is the plug with the black and green wire from the earlier picture. Unless I am digesting the information incorrectly, that needs to plug to something for the tach to work. I am not understanding the wiring.
Old Sep 29, 2015 | 12:45 PM
82F100SWB's Avatar
82F100SWB
The green wire needs to be connected to the negative side of the coil. There is supposed to be a corresponding plug on the engine harness.
Old Sep 29, 2015 | 02:22 PM
Lucille1986
One green yellow dot wire to coil
One green yellow dot wire to empty plug
One black green dot to distributor
One black green dot to empty plug
Old Sep 29, 2015 | 02:25 PM
Lucille1986
Also found this plug by firewall.
Black/white stripe wire
Green/white stripe wire
Old Sep 29, 2015 | 03:49 PM
Franklin2's Avatar
Franklin2
Sorry I haven't been more help. I am not sure myself, but you need to determine is the plug you have in the picture coming from the firewall or the engine? 82f100swb alluded in his post that the plug you are looking at actually is the one from the firewall, and you are missing whatever goes to the engine/coil.
Old Sep 29, 2015 | 04:08 PM
Lucille1986
Thanks for helping Dave, I appreciate it. It will eventually get figured out. It's just one of those things that is driving me nuts right now.
Old Sep 29, 2015 | 07:28 PM
maytag906's Avatar
maytag906
My 84 had the gauges, but no tach. I found a tach in an 86 at the boneyard. It didn't work, until I plugged in the harness in your post 3. Both ends were there, but they had never been plugged together. They were on the inner fenderwell, under the brake M/C.
