Sponsored by: Auxito
shifter linkage
Old Sep 27, 2015 | 10:03 AM
scottrkind's Avatar
scottrkind
shifter linkage
Having trouble with shifter not going into park. The linkage is sloppy. Is there a bushing kit or something to tighten up the linkage?
Old Sep 27, 2015 | 10:20 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Lay under the driver's side dash. Look up the steering column. There are two #30 Torx bolts that connect the bracket for the shift cable to the shift tube. They tend to loosen and even fall out. Tighten these bolts and it should work fine again.
Old Sep 27, 2015 | 01:05 PM
scottrkind's Avatar
scottrkind
thanks mark. just as you said, they were loose.
Old Sep 27, 2015 | 07:55 PM
toby tough's Avatar
toby tough
That happened to my 92 one time. put some Loctite on.
AliceSML79
29
Jul 5, 2015 11:33 AM
dmueller71
Mar 31, 2015 08:18 AM
noeld
1997 - 2003 F150
Feb 6, 2013 10:13 PM
KoolAidMan888
Jan 29, 2011 06:57 PM
302 F-150
Nov 8, 2007 06:34 PM
