Sponsored by: Auxito
shifter indicater
Old Feb 1, 2013 | 01:57 PM
noeld's Avatar
noeld
shifter indicater
my shifter indicater is off one on my 99 how do i get at it or what do i take off to adjust or fix it
thx noel
Old Feb 1, 2013 | 06:36 PM
projectSHO89's Avatar
projectSHO89
Is it "off" because it feels loose or sloppy?
Old Feb 2, 2013 | 09:47 AM
noeld's Avatar
noeld
not sure what you mean by loose its just not going on the rite letter
when its in reverse it shows on the indicater its in N
thx noel
Old Feb 2, 2013 | 10:40 AM
Lime1GT's Avatar
Lime1GT
If it's never been like that before and just started without any other work being done in the area it's probably the bolts have come loose at the end of the column shift tube. That piece has the shift cable attached to it.
Old Feb 2, 2013 | 01:19 PM
noeld's Avatar
noeld
????dont know i just got this truck mon & have no history what so ever it has several little things wrong with it,going to tackle them one at a time
thx noel
Old Feb 4, 2013 | 07:32 AM
Spotty's Avatar
Spotty
Crawl under the dash right under the steering wheel. Look at the firewall and you will see a black cable coming into the cab from the engine compartment. Follow that up and you will see where it hooks to a plate via a ball and stud. Look at the 2 gold colored screws that hold that plate to the shifter rod. Make sure they are tight. If that is OK look further up in that area and look for a little plastic nylon wheel...maybe the size of a quarter. Set the parking brake or block the wheels so it will not role away...put truck in neutral. Now turn that little wheel one way or another and it will move the pointer and you can center it on the "N".....good luck.
Old Feb 4, 2013 | 08:05 AM
noeld's Avatar
noeld
thx for that reply ill give it a try
Old Feb 6, 2013 | 10:13 PM
newfordy's Avatar
newfordy
shift indicator?
also. . . there is a shift tube mounted on top of the column. One end connects to the cable that goes to the trans and does the shifting. The other connects to the shift handle and indicator. Does your shift handle feel sloppy? If so, the shift handle, tube, bushings and plunger are surprisingly easy to replace as is the indicator itself. just tryin to help (by the way, my '01 is off exactly 1gear , the indicator has one end that sticks up in the instrument cluster and one that mounts a small wire to the shift tube. the mount on my tube is cracked just don't feel like changing it right now)
- keep us informed
scottrkind
1997 - 2003 F150
Sep 27, 2015 07:55 PM
AliceSML79
29
Jul 5, 2015 11:33 AM
norfolknova
Jun 17, 2015 08:06 PM
302 F-150
Nov 8, 2007 06:34 PM
Cracker289
Aug 31, 2004 01:15 AM
