Sloppy shifter
Old Mar 30, 2015 | 10:19 AM
dmueller71's Avatar
dmueller71
Sloppy shifter
All of a sudden, I have so much slop in my shifter that it won't go all of the way into Park sometimes. I pulled the cover off of the column, and I've read where the Torx bolts tend to loosen up. they seemed to be tight, but on the outermost clamp, there was a plastic sleeve that seems to belong in there, but slides out. I slid it back into place, and that helped a little bit temporarily (I think it slipped out again) but there was still a lot of play in the inned clamp. Are these sleeves easily replacable? Withoug pulling the steering wheel?
Old Mar 30, 2015 | 02:09 PM
dmueller71's Avatar
dmueller71
OK, Got it fixed. The dealership had the replacement plastic bushings, and they were a qiuck 5 minute replacement. That didn't solve the problem. At the bottom of the shift linkage (but still above center of the steering column, there is a mounting plate that mounts the shifter cable to the linkage. Same T25 bit tightened up the 2 loose bolts. Kind of a **** to get to them. Had to lay upside down on my back to see them in the first place, then just worked the ratchet up by feel to find the 2 bolts. Hopefully this helps someone down the road.
Old Mar 30, 2015 | 07:39 PM
pwstroker69's Avatar
pwstroker69
It will most definitely help me Dan. Mine has been doing this and getting worse for the past couple of months. I only hadn't asked yet because I'm recovering from knee surgery and can't do anything at the moment. It's on my list for this weekend though. Gracias!
Old Mar 31, 2015 | 03:47 AM
tjc transport's Avatar
tjc transport
i ain't rite
and sometimes tightning up those two unseen bolts will not fix the problem.
everything on my shift tube is tight, and it still will not go into park sometimes.
i have to make sure it is engaged before getting out of the truck, or it will roll away.
my problem is in the trans itself.
Old Mar 31, 2015 | 08:18 AM
pwstroker69
I *seriously* hope this is a shifter column part and not a trans problem, that would really ruin my day. Will add to this once I get to it next week for future reference.
randy06
Modular V10 (6.8l)
24
Sep 12, 2019 04:58 AM
scottrkind
1997 - 2003 F150
Sep 27, 2015 07:55 PM
esmarkey
May 30, 2013 07:33 PM
add2255
Aug 28, 2010 12:02 PM
F4O6R0D
Sep 30, 2005 10:07 PM
