Shifter Play
Old Nov 7, 2007 | 04:37 PM
302 F-150's Avatar
302 F-150
Shifter Play
When i got in my 97 E250 this morning and shifted into drive, the shifter felt loose. The shifter just moves freely without noticeably clicking into any of the gears. I cannot get it into park and I have to wiggle the shifter to get it to start. Does this sound like a problem in the steering colum/shift linkage or a problem in the transmission. The cable is also still attached on the transmission. Any suggestions?
Old Nov 7, 2007 | 05:09 PM
rclarke's Avatar
rclarke
That sounds like a broken shift tube. The shift lever is inserted in the top end and the shift cable at the bottom. Remove the plastic cover under the steering column to reach the 4 nuts holding the column to the dash. Disconnect the indicator cable and lower the column to the seat. You should be able to see the broken part and replace it.
Old Nov 8, 2007 | 06:34 PM
mhg's Avatar
mhg
also check the end of the shifter tube
the arm that pulls the cable has a couple screws that may work loose
