I have been studding lmc truck and was wondering if a new shift tube would fix my sloppy shifter so I could get it in and out gear without it flopping around?
You might just need to tighten two bolts. Looking up the column look for the bracket that attaches the shift cable to the shift tube. The two #30 Torx bolts tend to loosen and cause a sloppy shifter.
I have no real idea, would be hesitant to say "it's this or that......." without seeing in person your column.
In that write-up he should show two straps or caps surrounding the shift tube under which are plastic bushings. The attaching Torx-headed fasteners or the bushings have been known to need attention, often times solving a lot of that floppy shift lever syndrome.
It should also be noted at the bottom of that shift tube is an assembly that establishes the detents, those "steps" between gear selections. If that's worn regardless what's done elsewhere some of the sloppiness will remain.
Here's an exploded drawing showing the parts inside a column---looks more like a watch than an auto part huh? Items you'd want to check are numbers 12. 13 & 14:
You may have already already looked them, but I would check out the bolts and linkages near the transmission under the the body to make sure nothing is sloppy there.
ill check those bolts but need to get me some torx hardend secutiy socket tips.
ty fr the heads up on those bolts
You don't need any special Torx bits, the security bits aren't advised unless you encounter actual security-pinned Torx fasteners---they're a bit weak for most general maintenance uses.
The bolts mentioned should be torqued to a max of 15 ft/lbs---using LocTite #290 ("green") is helpful too.
I've fixed at least two vans for others this way. It was my first thought when I first saw the thread. One of those was bad enough that they couldn't find D on the shifter, didn't realize it, and were driving around in 2 or 1 thinking the transmission was all screwed up.
