Sponsored by: Real Truck
Trying to program remotes for '08 F250
Old Sep 21, 2015 | 08:06 PM
SDHauler's Avatar
SDHauler
Hello, just got my truck 08 F250 SC w/5.4L. Didn't come with remotes. Not on the sticker either...so I ordered from EBay after I got it to go into programming mode to lock/unlock. It's an XLT but not much of any other option (Snow prep and Trailer Towing Package).
Went through sequence and it entered programming mode but when I hit the button from the new Ebay remotes, nothing happened.
Any ideas?
Thanks!
Old Sep 22, 2015 | 01:33 AM
davester250's Avatar
davester250
By "not on the sticker", you mean the window sticker that details the options on the truck?
Maybe your truck doesn't have all the hardware necessary for remotes?
Old Sep 22, 2015 | 11:32 AM
bobv60's Avatar
bobv60
I don't think you have the reciever in the truck. I had a a 2003 that was the same. Had power locks, but no keyless entry. I have no idea about newer ones but the 99-07 had different wireing systems between the power locks with RKE and without. You best bet would be aftermarket. If it was me I would add the remote start with the rke.
Old Sep 22, 2015 | 06:12 PM
SDHauler's Avatar
SDHauler
Hardware to receive remote signals
Maybe you're right. But the truck does go into 'programming mode' ready to accept the signal from a 'new' remote (cycling ignition 8 times in 10 seconds). Are there any techs out there, maybe the dealer has to turn it 'on'? I checked the battery on the remotes (off ebay) and they're strong. They look like OEM remotes. (3 button square type).
Thanks
Old Sep 22, 2015 | 07:16 PM
Just Strokin's Avatar
Just Strokin
Are you sure you have the right remotes? Later model used a different remote than earlier models.
What are the numbers on the back of your remote?
Old Sep 23, 2015 | 07:49 PM
SDHauler's Avatar
SDHauler
Remotes are from Ebay
Larry, what numbers? The remotes I ordered from Ebay very cheap..you
mean frequencies?
Harry
Old Sep 23, 2015 | 08:53 PM
bobv60's Avatar
bobv60
Thanks
If you are getting into program mode I would think you do have RKE. Do you have the factory window sticker?
You can get the factory option list here, be sure to hit "more"
Vehicle Lookup
Old Sep 23, 2015 | 09:06 PM
SDHauler's Avatar
SDHauler
Less RKE
Bob, it says 'Less keyless entry'....weird since it still goes into programming mode..is that it? Is there a module I can buy or is it aftermarket?
Old Sep 24, 2015 | 04:42 PM
SDHauler's Avatar
SDHauler
Early Build
Looked at theVIN breakdown on that site and it's a MY 2007 Build Date. Wonder if the remotes are different.
Seahn
Feb 7, 2025 03:05 PM
ryno_rx8
Nov 3, 2012 06:32 AM
damons
May 31, 2012 07:12 PM
Ruikee
May 27, 2007 05:05 PM
ecajberry
Jul 3, 2004 11:06 AM
