Sponsored by: Real Truck
Remote Control Locks
Old Apr 10, 2007 | 11:16 AM
Ruikee's Avatar
Ruikee
Cool Remote Control Locks
Did a little searching and havent found a definitive answer. Just got an 07 F250SD XLT with the diesel. And it does not have a remote unlock. Over 40K for the vehicle and that wasnt part of the package? Can i get this added on or is it just not part of the plan. Also only has a single disk player with no satellite. Can i get that added on as well?
Old Apr 10, 2007 | 11:36 AM
firemanpat29's Avatar
firemanpat29
an xlt with out power locks? thats strange. I added the xm to my 2007 after I bought it, I use the little $50.00 Roadie and I works great.
Old Apr 10, 2007 | 11:40 AM
Ruikee's Avatar
Ruikee
It does have power locks and windows but no remote to unlock the doors and lock them. I thought it was kind of strange to have power locks with no remote.....
Old Apr 10, 2007 | 12:38 PM
RAGaz's Avatar
RAGaz
I had an '03XLT that did not have remote keyless entry either. I too thought that most XLT's included this option.
A quick way to determine whether or not your vehicle is equipped with the remote keyless entry option:
* put key in ignition
* cycle ignition between off and on positions 8 times within 10 seconds without starting the engine
If your vehicle is equipped with remote keyless entry, your power locks will lock and then unlock. If this happens, you can order new key fobs thru ebay relatively inexpensively (as compared thru the dealership). Instructions for programming your new key fobs should be included.
Good luck.
Old Apr 10, 2007 | 01:17 PM
rgrp944's Avatar
rgrp944
My XLT did not come with a remote, my dealer did install a remote entry and starter in lieu of fixing some minor scratch that really doesnt bother me.
I would try RAGaz advice, would be sweet if you only need to pickup a new key fob.
Old Apr 11, 2007 | 09:44 AM
Ruikee's Avatar
Ruikee
Dont Have them
Looks like the test resulted in no installed system. Where and what should i look for in an aftermarket system?
Old Apr 11, 2007 | 10:14 AM
TXHillCountry's Avatar
TXHillCountry
FYI.. When you do the key cycle test, make sure you're doing it from the right position.
Position 1 is all the way back, sometimes called the "accessory" position. Position 2 is the "Locked" position, the one where you leave it when you shut off and remove the key.
Position 3 (and the position you want to start the test from), is called the "Off" position. (I know, a little confusing).
Position 4 is the "full accessory and run" position (where you want to stop the test).
Position 5 is "Start"
So you put the key in the ignition (and you're most likely now in Position 2).
Turn one more click to Position 3 (Off) and then from there turn to the next Position (4) and back again to Position 3 eight times within 10 seconds, and end up the last time in Position 4.
Then, if you have keyless entry, the locks should cycle letting you know your in key-fob programming mode.
This is described towards the end of the section called Locks and Security in your owner's manual under the "How to reprogram your remote entry transmitters" section.
rgds,
TX
Old Apr 11, 2007 | 11:24 AM
Ruikee's Avatar
Ruikee
Yep, tried it again and the locks dont move. I just cant beleive that you spend over 40K on a vehicle and in this day and age, it wouldnt come with a remote for the locks. Any aftermarket stuff i can look for?
Old Apr 11, 2007 | 11:43 AM
Flatdeck's Avatar
Flatdeck
Just install an alarm.
Old Apr 11, 2007 | 12:17 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
When I bought mine (off the lot), it too had the power locks and windows, but no remote 'clicker'. Just told the saleman that the sales depended on them 'installing' the remote system. By the time a got back off the test ride, the salesman was inside the showroom, locking and unlocking my doors with the remote!! (And laughing like mad)Incentive is a great motivator!
Old Apr 11, 2007 | 08:31 PM
mooch91's Avatar
mooch91
Same experience here. Salesman tried to tell me that my 2007 XLT did not come with remote keyless. I questioned three times before he asked a colleague who showed him how to program two remotes to the truck. Within a few minutes, I had my remotes.
I'm not sure if it was part of the XLT package or the "advanced security group" the truck was equipped with.
Old May 27, 2007 | 12:02 AM
MNExpedition's Avatar
MNExpedition
My 1998 F150 XLT Supercab did not come with remote door unlock either. It does have power windows and door locks. I can not find the RAP unit under the dash. That would allow keyless entry and remote door opening. Might be better off installing an alarm system.
Old May 27, 2007 | 05:50 AM
josh04hdf250's Avatar
josh04hdf250
Imo-use The Opportunity To Buy A Trick Alarm/remote Start/etc System That Will No Doubtedly Have The Remote Entry Option!
Old May 27, 2007 | 04:48 PM
esco24's Avatar
esco24
anyone know how to reprogram the keyless remote? i have 02 f350 and my just stop working ,changed the battery no luck when i lock the door from inside the parking lights flash
Old May 27, 2007 | 05:05 PM
F250_'s Avatar
F250_
esco24... look in your original thread. I answered there.
