HEART BREAK
Old Oct 4, 2015 | 06:59 PM
  #46
MYTRUCKNOWRATTLES's Avatar
MYTRUCKNOWRATTLES
You sure have a lot of patience man. Not sure I could be that long with out the truck and they still have not figured it out.
Best of luck hope you get it back soon.
Old Oct 12, 2015 | 09:41 AM
  #47
astecasphaltman's Avatar
astecasphaltman
Here is the latest. They did find one of the cardboard disc from the top of a Motorcraft PM22A fuel treatment in the sending unit. It would restrict the fuel pick up tube off and on.
A word of warning. The sending unit and the tank had been inspected twice without finding the issue. The tech has to be looking to find it. Had the truck back five days and all seems good. I hope that is the issue.
Old Oct 12, 2015 | 09:47 AM
  #48
SavageNFS's Avatar
SavageNFS
I'm happy to hear you've gotten your truck back! Fingers crossed the issue is resolved. I can't believe they found anything in the sending unit after inspecting it twice and claiming to replace it once (see your post here). At any rate, thanks for the update and I hope this resolves the issue!
Old Oct 12, 2015 | 10:46 AM
  #49
Nick in Maryland's Avatar
Nick in Maryland
Can't believe it took all that. Restriction and aeration checks should always be performed with a failed pump.
Glad you have her back.
Old Oct 12, 2015 | 11:22 AM
  #50
Ford_Doctor's Avatar
Ford_Doctor
I guess this was not as unusual as I thought! As you mentioned, this had to be scrutinized carefully to find. Glad to hear this is resolved but keeping my fingers crossed for you as well.
Originally Posted by Ford_Doctor
I know a technician that found a cardboard disc from a fuel additive cap floating around in the bottom of the pickup bowl, part of the fuel pickup and sender assembly inside the fuel tank. The fuel pump inlet restriction test would pick up something like that.
Old Oct 12, 2015 | 03:54 PM
  #51
FTE Herman's Avatar
FTE Herman
Oh *****, I know I've dropped at least one of those in my tank.
Superdave71
6.7L Power Stroke Diesel
Jan 26, 2018 02:48 PM
eichenlaub
Jul 16, 2013 07:51 PM
DeereTech05
6.4L Power Stroke Diesel
24
May 9, 2010 01:50 PM
YZGUYONE25
May 28, 2009 07:37 AM
JTs Bronco
1978 - 1996 Big Bronco
Mar 4, 2004 08:59 PM
