Fuel leak from behind the fuel filter
Received 3,108 Likes
on
Are you sure it is coming from the fuel bowl?
If it is which is common it could be the fuel bowl drain valve. (Yellow valve on the back)
Another potential spot for a leak is the pass side fuel line from the bowl to the rear of the head. That fuel line tends to crack in the middle just under the "Y" pipe where it clamps the plenum.
There are two typical fuel leak sources in the valley: One is the passenger-side fuel line under a clamp, held by an intake plenum bolt. The other is the fuel bowl drain seal. When that drain seal goes, the rest of the seals in the fuel bowl are in just as bad shape - so everything needs a rebuild. Diesel O-rings and Riffraff Diesel have the toys.
I bought these to start working on mine as well. I am hoping I got the right ones. I also have to remove the HPOP for a leak on the Non serviceable plug.
#8-007 Serviceable Replacement HPOP Plug 8-007 1 $28.45
#8-009 HPOP Engine Mounting Gasket 96-03 8-009 1 $24.89
#7-025 Complete Fuel Bowl Drain Valve
Type of Drain Valve O-rings
Blue - Fluorosilicone (best)
7-025blue 1 $45.41
#7-003 Fuel Bowl Reseal Kit 1999-2003
Black - Viton A (good)
7-025blue 1 $45.41
on
7-025blue 1 $45.41
7-025blue 1 $45.41
