Batteries
Old Sep 29, 2015 | 08:13 AM
  #91
CPB1's Avatar
CPB1
Originally Posted by white Buffalo
Can you dip the copper lugs in some melted solder or grease them up?
Yea I can tin the lugs with Tin/Lead solder. I just didn't want to have to do the job twice. Not a problem, it's not that hard of a job.
Thanks guys
Old Sep 29, 2015 | 02:55 PM
  #92
white Buffalo's Avatar
white Buffalo
Originally Posted by CPB1
Well I'm in the same boat. Went by Napa today and gota replacement with the tin lugs.
Old Sep 29, 2015 | 03:26 PM
  #93
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
You guys are stressing way too much over copper lugs IMHO.
Josh
Old Sep 29, 2015 | 03:56 PM
  #94
white Buffalo
Josh
Your right Josh, but I'm a professional worrier-LOL 😎
Old Sep 29, 2015 | 04:59 PM
  #95
Mark_in_co's Avatar
Mark_in_co
I keep following this thread as I haven't had a chance to do it yet, but this is all great info!
Got in the truck after it had set for 3 days, batteries read 10.7v on the reader. Started it up and the system went to 12.5ish with about 20-30 seconds after starting. After driving it a few minutes it went up a bit further. Looks like new batteries are coming soon. I'd better get off my **** and get this done!
Here's my shopping list as I've pieced together since the last one posted:
1- 24" 1/0 gauge with a 3/8 lug on one end and a 5/16 on the other both tinned
1- 36" 12 gauge or better with 5/16 tinned lugs on both ends. Probably will just go with 1/0 as it'll look cool
1- M10-1.25x25mm bolt
Did I get it right?
Been shopping around online and looks like the CAT batteries are about the best deal going. Probably gonna pick up a set of those too. $135 or $130 I think they were.
Old Sep 29, 2015 | 05:11 PM
  #96
WatsonR's Avatar
WatsonR
Did I get it right?
The long one red, short one black. Ask for tin connectors, they may carry them.
Old Sep 29, 2015 | 05:36 PM
  #97
TooManyToys.'s Avatar
TooManyToys.
3/8" both ends is what I used.
Are we obsessing too much about tin plated copper lugs ..... Well yes, don't we do that with our modifications?
But I also had to laugh in comparison to my other hobby, high end audio. Single crystal copper power cords with cryo treated plugs and sockets, etc., cryo teated 1 amp fuses, etc.
Here is a power cord for for an amp, player, or whatever:
https://app.audiogon.com/listings/ac...10-new-york-ny
I won't even bring up speaker wire. Tin plated cable lug, not even in the ballpark.
Old Sep 29, 2015 | 06:11 PM
  #98
Mark_in_co's Avatar
Mark_in_co
WOW! That is an expensive hobby! I know where the name TooManyToys comes from now!
Old Sep 29, 2015 | 07:14 PM
  #99
TooManyToys.
It's a slippery slope but I've stayed close to the rim. Although if my wife knew (she doesn't want to know) what my audio system cost she'd think I've way over the edge. I do however make my own cables.
TMT comes mostly from things automotive however.
Old Sep 29, 2015 | 08:53 PM
  #100
CPB1's Avatar
CPB1
Did I get it right?
I only did the ground cable with 3/8 eyes on both ends, and if your gonna get on the head where I did the M10 bolt didn't fit.
Old Sep 29, 2015 | 10:24 PM
  #101
Mark_in_co's Avatar
Mark_in_co
I've got an '05 as well. What size was the bolt you used?
Old Sep 29, 2015 | 10:51 PM
  #102
TooManyToys.
I have to call a yellow caution on that. Nothing I've done with Ford or International for decades has been in the inch measurement system, all metric. And a 3/8-16 is really close both in diameter and pitch to a 10-1.5mm so it might not hurt to double check the threaded hole.
Old Sep 30, 2015 | 07:01 PM
  #103
CPB1's Avatar
CPB1
I used a 3/8x16 bolt.
I bought a "10mm x 25mm metric hex cap fine" from NAPA and it crossed right away. I thought this was the one listed for this mod. I think it is metric but cores thread, not fine.
I ran a 3/8x16 tap in the virgin hole to clean it up and it was tight but didn't feel like it was cutting. I threaded the bolt on and snugged it up tight no problem.
Maybe Jack knows the correct size bolt, I don't think I am any help on that, sorry.
Old Oct 4, 2015 | 10:07 AM
  #104
TooManyToys.
There are three threads available in the 10mm size: 1.00 (very fine), 1.25 (fine), and 1.50 (course).
Based on what's in my bolt box and what I have receipts for over the past quarter I believe I used 10-1.50 thread.
Old Oct 5, 2015 | 11:34 AM
  #105
CPB1's Avatar
CPB1
Interesting observation
Yea I bet that's the correct size 10mmx1.50
Since installing the extra ground cable I noticed an increase in charging voltage just after start up when the glow plugs turn off and the alternator takes over. I am seeing 14.1-14.2 volts just after start up then settles down to about 13.6 volts after about 1/2 hr of running. Not sure why this is but my starter does sound like it draws a lot of current during a cold start. Maybe needing a new starter.
