Batteries
Old Sep 25, 2015 | 06:50 AM
  #61
white Buffalo's Avatar
white Buffalo
Originally Posted by Mark_in_co
I'm gonna add this to my list of things to do before winte............................................. .....
me too
.................................As you've noticed from not burning up your OE wiring with the higher output alternator, the 140a unit stays under 110a at normal startup idle so you've been fine for these few months. But at some point you need an additional wire so provide both full support and protection for the extra 30a. The 36" 12ga wire from the alternator output post to the battery positive terminal will provide more then enough of a path, and the easiest way to provide fusing is with a setup used in my neck of the woods for boating and available through Amazon or a boating supply store. When I had a 140a unit in place I used a 40a to give me a little headroom so it didn't quick blow.
For the 1/0 cable you can get that made up at a NAPA store with 5/16" lugs for a reasonable price or order one through Amazon or eBay. NAPA is my normal go to place and they might even be willing to make a 12ga wire too. Usually anything smaller then 8ga I make up myself.
The 1/0 goes from the drivers frame connection to a boss to the right side of the crankshaft pulley...................................
Gonna try to stop by NAPA this morning, here is my shopping list:
1) 24" 1/0gauge with 5/16" lugs (NAPA) for the drivers rail connection point to the engine block. connects at a boss by the power steering pump.
2) 36" 12ga wire (fused or fuseable link) with 5/16" lugs from the alternator output post to the passenger battery positive terminal
Just wanted to post this to have you guys look over and make sure I didn't make a mistake. I'm not 1/10th as knowledgeable on this subject as you guys are...... Just don't wanna burn her down after al the work I'm doing!
Old Sep 25, 2015 | 07:29 AM
  #62
TooManyToys.'s Avatar
TooManyToys.
I'm having one of those moments, heh I'm old. Let me make sure the negative connection was 5/16 and not 3/8.
Old Sep 25, 2015 | 07:31 AM
  #63
WatsonR's Avatar
WatsonR
the passenger alt bat wire can be bigger, just that the 12ga is the size recommended to carry that load. Personally, I'd do a little bigger so that when the wire begins to degrade you still have some reserve.
Remember, the bigger the wire the less resistance it has.
AND clean all the grounds down to bare metal on both the connector and attaching point.
Old Sep 25, 2015 | 08:08 AM
  #64
TooManyToys.
The frame / engine lugs are 3/8" (or 10mm) and you will need a 10-1.5x25mm bolt for the engine block connection.
Randy is right you can up that to a 10 or an 8ga. 12ga was actually up from the 14ga as that is all that was needed. If your NAPA is not into making that wire and it's not something you normally do let me know by pm.
Old Sep 25, 2015 | 08:58 AM
  #65
TooManyToys.
I have to apologize, I was going to do this a while ago but haven't been feeling that well.
Here is the cable setup I did. You have to pull the air filter, battery, battery tray and the CAC tube.
Old Sep 25, 2015 | 10:14 AM
  #66
white Buffalo
No apologies necessary, without this thread I would never have known. Awesome pics - thanks!
Old Sep 25, 2015 | 10:21 AM
  #67
white Buffalo
Gonna take care of this while the cab is off for head studs.......
Old Sep 25, 2015 | 11:45 AM
  #68
coolfeet's Avatar
coolfeet
Most of the peeps here have the F series 6.0. I have the E350 van and I need a little guidance for charging my batteries as they are located on the frame rail under the van.
I see a red capped jump starting port on the frame rail. Should I connect a trickle charger here to maintain the battery?
There is also + - in the main power distribution box. I don't know much about charging from here. When I bought the van, the tow truck tried to jump from this area and was not successful. He eventually found the jump starting points on the frame rail.
I have a CTEK charger and want to install a quick connect on the charge points. I have the alligator clips and don't trust them to stay on.
Old Sep 25, 2015 | 12:50 PM
  #69
TooManyToys.
You should do it from the frame rail if you don't want to pull down the batteries and do them individually. It is best to do one at a time normally, but you should be fine with a trickle charger.
Old Sep 25, 2015 | 01:52 PM
  #70
HT32BSX115's Avatar
HT32BSX115
In making my own cables, I have even gone as far as to "tin" the wire first and solder the crimp-connectors directly to the wire.
Then use an anti-corrosion sealing substance on the connections before tightening the bolts so as to maintain the low resistance connections.
Old Sep 25, 2015 | 01:57 PM
  #71
TooManyToys.
White Buffalo, that's cheating.
While I had the new cable exposed I thought I'd see what the current was running through it .... And to continue to learn how to work with video on this iPad rather then my camera.
The current during the glow plug warm up is about half of what I had seen while monitoring the positive cable, which I expected. But when starting the motor the current is way higher then what I expected to see, so I think when I previously looked at the current flow during starter engagement off the positive cable the value was low due to the ceiling of this ammeter. So we may be pulling more current during starting then what thought was occurring.
Old Sep 25, 2015 | 07:05 PM
  #72
smlford's Avatar
smlford
Im really a novice when it comes to all things electrical but I found a nice explanation on the short comings of our electrical system and how to improve it from ficm repair.com
Alternator wiring
Old Sep 25, 2015 | 08:34 PM
  #73
TooManyToys.
Good luck with that.
Old Sep 25, 2015 | 09:25 PM
  #74
white Buffalo
The frame / engine lugs are 3/8" and you will need a M10-1.25x25mm bolt for the engine block connection.
got it - you were spot on with NAPA, $24 and 15 minutes and I was out the door!
I try
Old Sep 25, 2015 | 10:21 PM
  #75
TooManyToys.
Did they also crimp on the lugs? They will do that for free.
