E4OD transmission swap
Old Sep 6, 2015 | 03:59 PM
Fordman4810's Avatar
Fordman4810
I'm trying to figure out how to put a 2wd van E4OD transmission into a 1994 Ford F-150 4.9L 4x4. Is it possible to do the swap? And if so, what do I need and what should I do?
Old Sep 6, 2015 | 04:41 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
What engine was the E4OD mated to in the van?
What transmission did the F-150 have?
You can change the E4OD from a 4x2 to a 4x4 transmission. Tear the trans completely down. Start putting it back together with a 4x4 output shaft. It's a different shaft than the 4x2 one. You'll also need to change the extension housing, the one on the 4x2 trans accepts a driveshaft, you need the 4x4 housing that mounts a transfer case.
Old Sep 6, 2015 | 05:00 PM
Nothing Special's Avatar
Nothing Special
Is it possible? Yes. Is it worth doing? Rarely. Look at what Mark said you need to do in order to do it. I'd say the only situation where it would be worth it is if you had a 2WD transmission that needed to be rebuilt that you wanted to put into your 4WD truck, AND you had a 4WD transmission that was shot, that you didn't want to rebuild, that you could steal the tailshaft and extension housing from.
I'd say that at least 99 times out 100, if you have a donor trans to get the 4WD part from you're better off rebuilding it then converting a 2WD trans.
Old Sep 7, 2015 | 08:26 AM
'89F2urd's Avatar
'89F2urd
I don't even know of a trans that is worth converting form 2wd to 4wd...they all need mainshaft/output and housing swaps.
Vanet
35
Mar 4, 2014 09:02 AM
86notcg
Feb 25, 2011 04:09 PM
Pacerguyel2
Nov 24, 2005 10:00 AM
carnuck
Feb 16, 2004 09:14 PM
Lognomore
Aug 29, 2002 01:14 PM
