Throttle Cable Q's
Old Aug 2, 2003 | 02:10 PM
VX's Avatar
VX
Throttle Cable Q's
Did the 2BBL and 4BBL 352's use different throttle cables? I converted my '66 to an Edlebrock Performer intake/Holley 670 Avenger carb and, while pleased with it overall, my throttle cable has a pretty good "S" curve in it with some binding, along with laying on one of my valvecovers. What is the best way to correct this? Pictures?
Any help is greatly appreciated!
Aaron
Old Aug 2, 2003 | 02:35 PM
Putt's Avatar
Putt
Throttle Cable Q's
I just looked at my '66 with a Performer(been awhile since I installed!)- I added a short~1 inch piece of metal to the cable bracket on the manifold. It moved the cable up and slightly forward to better line up with the carb. Painted black it's almost invisible.
Hope this helps!
I don't think a 4bbl was even an option in '66 ?
Old Aug 3, 2003 | 03:54 PM
VX's Avatar
VX
Throttle Cable Q's
Are you using stock valvecovers, Putt? Directly from the firewall, my throttle cable is inline with my tall Milodon valvecovers, thus the reason for the "S" curve. I'll try to get a picture or two this week.
Old Aug 3, 2003 | 10:02 PM
Putt's Avatar
Putt
Exclamation Throttle Cable Q's
Like I said its been awhile since I installed... After another look and dredging in the memory banks, I see what I did.
I also moved the acc. pedal bracket up about an inch maybe slightly more. The bracket is big enough to cover the old holes, you just need to add a couple and trim the firewall insulation. My valve covers are aluminum Holley/MT covers and they are taller than stock, altho I don't remember how much. I think I pulled the cable and bracket and checked the location by "eyeballing" how far up I needed to go. It does change the pedal position, but not so much that it is a problem. It just took a little while to get used to it.
Memory is a terrible thing to lose, wish I could find mine!!!
Old Aug 4, 2003 | 03:06 AM
VX's Avatar
VX
Throttle Cable Q's
Sounds like I've got a little drilling lined up tomorrow! Thanks, Putt!
Old Aug 4, 2003 | 08:54 AM
Putt's Avatar
Putt
Throttle Cable Q's
Glad I could help! You'll like the extra UUMPH of that new setup!!
Q's 86
Aug 16, 2008 10:06 PM
N7ghtwolf
Sep 14, 2007 10:21 AM
yozsi
23
Jan 29, 2005 12:36 AM
Wakeboarder141
Jul 14, 2004 04:48 PM
mustangmaniac
Nov 7, 2003 03:43 AM
