i need to replace my throttle cable
Old Aug 16, 2008 | 04:04 PM
Q's 86's Avatar
Q's 86
i snapped the throttle cable on my 302 with a 2bbl. its stranded on the side of the road. how hard is this to do on the side of a road and what tools will i need?
Old Aug 16, 2008 | 06:22 PM
Sycostang67's Avatar
Sycostang67
It's very easy, all you will need is possibly some needle nose pliers and a basic socket set or maybe just a screwdriver depending on how easy it is to reach. You can use the pliers to pop(it should just pop right off) the end of the cable off the carb and slip the other end off the gas pedal. There should be 1 large sheetmetal screw retaining the cable to the intake manifold. Remove that and then pull out the cable.
Old Aug 16, 2008 | 10:06 PM
Q's 86's Avatar
Q's 86
thanks i got it. but im about to change out my carb to a four bbl edlebrock and intake. how easy is it to do this? its already been tuned for a 302 which was in a tbird i have
damarble
1997 - 2003 F150
Jan 23, 2014 03:40 PM
bigdogridge
Dec 11, 2006 02:02 PM
runner
13
Oct 6, 2006 04:15 PM
