Help! Replacing E40D MLPS
Old Jul 11, 2004 | 02:00 PM
Wakeboarder141's Avatar
Wakeboarder141
Exclamation Help! Replacing E40D MLPS
I am trying to replace my MLPS before it starts raining and I have run into a problem. I am assuming the large nut that runs through the middle of the sensor that hold what I am assuming is the throttle cable off, but it does not want to budge. Am I correct in wrenching on it to break it lose? It has me worried because it moves that linkage when I try to break the nut lose. Any help would be appreciated. Thanks.
Aaron
1993 Bronco 351W E40D
Old Jul 11, 2004 | 04:12 PM
Ponyracer's Avatar
Ponyracer
use a pair of pliers to hold the shift lever still while you carefully loosen the nut. try and keep the trans in neutral to easy in installation of the new MLP
Old Jul 11, 2004 | 04:20 PM
Wakeboarder141
Thanks, got that. Now the problem is getting the wires out of the old connector. Any hints on that or should I just smash it to pieces and break the wires out?
Old Jul 11, 2004 | 04:26 PM
Ponyracer's Avatar
Ponyracer
remove the red keeper inside the connector, then look inside and see the little clips that hold the wire ends in place, use a pick to move the clips and carefully pull out the wires, make sure and mark where they came from or just transfer one wire at a time to the new connector
note if you have a Ford part the instructions have the drawings that change view angles so dont be fooled. and make sure your battery is disconnected, if you touch two of the wires you can start your vehicle
Old Jul 11, 2004 | 04:32 PM
Ponyracer's Avatar
Ponyracer
mark down the wiring on the old connector on paper to refer back to if you have trouble
Old Jul 11, 2004 | 04:35 PM
Ponyracer's Avatar
Ponyracer
almost forgot, add dielectric gel inside the conector when you connect it, this will water proof the connection which is the main reason for the switch going bad usually
Old Jul 11, 2004 | 06:00 PM
Wakeboarder141
Thanks for the advice. I got the wires all out and the thing installed. Now the problem is that when starting it acts like it doesn't have enough power to turn the starter. If I hold the key to start it will turn over, pause, turn over, pause, etc. until it finally will turn over a few times and start. Does that sound like we somehow killed the battery while working on it or is something wired wrong? Thanks.
Old Jul 12, 2004 | 07:40 PM
Ponyracer's Avatar
Ponyracer
are you sure the wires are correctly installed into the new connector. it is easy to get a couple mixed up. Or you might not have the MLP aligned correctly. recheck you work and let me know what you find
Old Jul 12, 2004 | 08:39 PM
Wakeboarder141
I tried jump-starting my truck and it started fine. Would I be safe to assume the battery was somehow damaged? I am going to get it tested tomorrow, but that seems like the logical assumption to me. Thanks for you help.
Old Jul 14, 2004 | 04:48 PM
Wakeboarder141
Replaced the battery and it starts better than ever now. Must have somehow fried the old one. Lesson learned. Now to pull the codes again and see why I still have a check engine light coming on after 10 min of driving.
Ceaumar
Apr 22, 2016 10:54 AM
tezm
Sep 25, 2014 05:26 PM
LSO1123
Oct 1, 2011 12:12 PM
gulfcoast
Sep 17, 2006 05:57 PM
Wakeboarder141
1978 - 1996 Big Bronco
15
Aug 4, 2004 09:48 AM
