o/d off button wigging out
Old Aug 21, 2015 | 11:48 AM
varminthunter243's Avatar
varminthunter243
the Overdrive off button on the end of my shifter has been acting up for a while. Used to work if I pushed the button while I had the shifter pulled up, then it got worse and I had to wiggle it to make it work, now it seems to have quit all together. With the wiggling fixing the issue for a while I'm wondering if it's a connection at the base of the shifter or in the column and so in wonder if I should bother with replacing the shifter arm or what? Leaving for an elk hunt in a week and I'll most likely be pulling a trailer down so I'd like to have it working. Any ideas?
Old Aug 21, 2015 | 11:52 AM
Thomas White's Avatar
Thomas White
It's either the Switch, ($35 OEM?) Or, the Connection at the Switch. But, just as likely the wiring harness through the column is worn or chafed.
Easy check for all three.
Old Aug 21, 2015 | 01:52 PM
varminthunter243
Ok. I will look at it sunday along with an oil change. How does the switch come off the end of the shifter? Threaded or does it just pry off?
Old Aug 21, 2015 | 02:09 PM
tdpower's Avatar
tdpower
I have a new switch and end cap if you need them I will let it go cheap. It's the same as this one: http://www.amazon.com/Overdrive-swit.../dp/B007JKV9PE
You have to order the end cap separate:
http://www.amazon.com/Ford-F2UZ7A214...569008-2354223
Old Aug 21, 2015 | 02:38 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It's not the switch. 99.9999% of the time it is going to be the wires have worn through or broken where they enter the shift handle inside the column. You can remove the plastic cover from the column and either fix the wires or replace the shift handle. A new handle is about $65 at a Ford dealer.
Old Aug 21, 2015 | 02:42 PM
tdpower's Avatar
tdpower
You just pry it off. If you order a new gearshift leaver it comes with the switch, end cap and overdrive wiring down to the plug. Shoot me a pm if you are interested in that stuff. I'm in ABQ, NM
Old Aug 21, 2015 | 02:49 PM
tdpower's Avatar
tdpower
Looks like this is the gearshift handle: http://www.amazon.com/Ford-F4TZ-7210...953276-3753031
That one doesn't come with a new switch.
motopsyko32
May 26, 2009 02:23 PM
red01
1997 - 2003 F150
Jul 4, 2008 09:49 PM
outdoormaniac
Feb 13, 2008 10:06 AM
psd tuner
Mar 12, 2007 06:30 AM
mnikkel
Jul 9, 2004 04:27 PM
