Broken 4wd
Old Aug 15, 2015 | 05:10 PM
Scarydecoy's Avatar
Scarydecoy
Broken 4wd
Help... When I switch from 2h to 4h i get a 4x4 error on the information screen some times and other times it works fine. So I been playing with it a bit and I have noticed when I put the switch from 2h to 4h it will show on the dash I am actually going into 4l instead of 4h. I am trying to get a idea what would cause this. I have a extended warranty on the truck, but if it is something easy to fix then I rather just do it myself.
The truck is a 2011 F-150 3.5eb Lariat Supercrew if that helps.
Any help would be appreciated.
Old Aug 15, 2015 | 07:18 PM
PrinceValium's Avatar
PrinceValium
Well that would be pretty impossible on the move since it takes you to be in neutral to shift into 4 wheel low.
Old Aug 15, 2015 | 08:07 PM
Scarydecoy's Avatar
Scarydecoy
It should be impossible but trust me the grinding and horrible noise says other wise. It is defiantly trying to and the light on the message center says it's trying to go 4l even though the **** says 4h.
Old Aug 15, 2015 | 11:22 PM
PrinceValium
I would surely take the truck in to the dealer.
Old Aug 17, 2015 | 10:05 AM
Scum Frg's Avatar
Scum Frg
You say u have warranty......time to use it with a visit to the dealer
Old Aug 17, 2015 | 10:34 AM
FordService's Avatar
FordService
Official Ford Rep
Help... When I switch from 2h to 4h i get a 4x4 error on the information screen some times and other times it works fine. So I been playing with it a bit and I have noticed when I put the switch from 2h to 4h it will show on the dash I am actually going into 4l instead of 4h...
Hi Scarydecoy,
As some of the other folks have suggested, it sounds like it's dealer time to me. How many miles are on your truck?
Crystal
Old Aug 17, 2015 | 07:57 PM
Scarydecoy's Avatar
Scarydecoy
It has 65k on it. I got a hold of the wiring diagram and the transfer case motor seems to put it in 4l and 4h obviously, but it also looks like it senses if its in 4h or 4l. I am guessing that motor is going to far and then also seeing it is to far. That's about the only thing I came up with.
I will take it to a dealer next few days i think. Kinda swamped at work atm. When I do I will update this thread.
Old Aug 18, 2015 | 08:19 AM
FordService
Official Ford Rep
...I will take it to a dealer next few days i think. Kinda swamped at work atm. When I do I will update this thread.
Sounds like a plan, Scarydecoy. I'll continue to monitor this thread to see when you have any news to report.
Crystal
4x4greenbeast
17
May 22, 2014 12:10 PM
brazoriastang
2004 - 2008 F150
Jan 19, 2010 11:01 PM
Urthman
Feb 20, 2007 08:52 PM
seaweaver
Aug 25, 2006 09:29 AM
rdemkowicz
1997 - 2003 F150
Jan 28, 2005 04:03 PM
