4WD problems need advice please
Old Jan 16, 2010 | 02:16 PM
brazoriastang's Avatar
brazoriastang
My truck sometimes will not go into 4WD. I switch the **** to 4WD and nothing at all happens. Usually after a little while, maybe 20 minutes if I try it again it will work. Seems like to me there is a possible loose connection to the switch. I replaced the solenoid a couple months ago thinking the old one was bad.
Does anyone know how to get the switch off? The plastic **** in the cab doesn't seem to pop off.
Thanks
Old Jan 16, 2010 | 02:20 PM
kevincw's Avatar
kevincw
My explorer has a 4X4 control module. Check to see if you have one and if the conntacts are clean.
Old Jan 19, 2010 | 11:01 PM
dtingle89's Avatar
dtingle89
do you want 4H or 4L?
4H should shift automatically when switched from 2H. 4L is different, you have to Put truck in neutral, switch to 4L, and wait for light,
rossgn
Dec 9, 2013 09:18 AM
White EddieB
Aug 26, 2011 10:22 AM
dhobdey1
Nov 28, 2009 08:39 AM
jrdufford
Oct 14, 2008 09:08 PM
tmwindham
1978 - 1996 Big Bronco
Oct 24, 2004 12:10 AM
