Transfer case compatibility
Old 08-13-2015, 02:29 PM
84-250's Avatar
84-250
84-250 is offline
My transfer case in my 94 f350 just started dumping a lot of aluminum shaving into the oil, it has 282k miles on it. Just changed oil 20k ago.
I found a transfer case from a 93 f150, manual shift and slip yoke output like mine.
Will it work?
Mine has a pto option but does that matter?
What is with the different metals, mine is mag and aluminum case halves.
I'm rebuilding before I do the swap so I don't have a long downtime waiting for parts.
Old 08-13-2015, 05:38 PM
Vertrees's Avatar
Vertrees
Vertrees is offline
Which TC is in the truck now, and which one is in the 1/2 ton? I did kind of the same thing. I pulled a TC out of a 1980 3/4 ton Borg Warner 4 spd and swapped it over to my 97 F350 with the ZF S5-42. (My 1980 was not factory by any means though. Had a 460 down in her, so the drive train was probably from a different truck as well. I believe it was the NP208 that it had in it.
Old 08-13-2015, 07:46 PM
84-250's Avatar
84-250
84-250 is offline
Both are BW 1356
Both are manual shift with slip yoke
If I'm correct, the front yoke is different? Will mine just swap over?
Old 09-13-2015, 08:50 PM
84-250's Avatar
84-250
84-250 is offline
Update: I drove another thousand miles and dumped the transfer fluid, still have a lot of glitter( no 4x4 action).
In the local junkyards I found a transfer case with 47k miles. It's out of a 95 f250.
Is the front yoke swap just an unbolt and swap ordeal?
Besides losing the PTO option, are there any drawbacks?
Old 09-13-2015, 10:00 PM
82F100SWB's Avatar
82F100SWB
82F100SWB is offline
The yoke will swap over. I have interchanged pto and non pto cases with no issues.
Old 09-14-2015, 06:04 PM
84-250's Avatar
84-250
84-250 is offline
Would you happen to know the nut size and if there is a torque spec?
If you had the option, find one from a f150 or f250? Just go for least miles? Certain years?
I just want to swap it over and be carefree for another 100k miles
Old 09-14-2015, 08:26 PM
farmert's Avatar
farmert
farmert is online now
The 1356 cases are all the same, 150, 250, 350, With the exception of the front yoke. Go with the best value to lowest miles.
Old 01-25-2019, 06:58 AM
Vince Zuber's Avatar
Vince Zuber
Vince Zuber is offline
2009 f250 super duty diesel transfer case
will a 2002 f250 transfer case fit on a 2009 f250? I need a new transfer case and front and rear driveshafts and I’m wondering if a 2002 parts will fit a 2009??
duct tape F-150
22
05-05-2013 08:15 PM
bowman91centurion
04-29-2013 09:52 AM
Eddiec1564
05-04-2007 07:27 PM
cwpitman
12-11-2005 09:58 AM
baw289
1978 - 1996 Big Bronco
01-26-2004 08:05 PM
Quick Reply: Transfer case compatibility
