HOW TO REMOVE THIS SHIFT KNOB!!!!!
Old Aug 3, 2015 | 09:33 PM
anthonym92's Avatar
anthonym92
HOW TO REMOVE THIS SHIFT ****!!!!!
okay so im trying to add some personality to the beast and well i cant seem to remove the shift **** to add an aftermarket one. is there some frickin special way to do it? this thing is like welded on it seems (impossible since its plastic/rubber). any advice?
Old Aug 3, 2015 | 09:36 PM
85e150's Avatar
85e150
Year, model, engine and which trans will help.
AFAIK most are glued or pressed on the shaft. Not easily removable without damage to the shifter ****. That's the way my Ranger was. Of course, it came off itself a couple times....
Old Aug 3, 2015 | 09:44 PM
anthonym92's Avatar
anthonym92
88 f15o xlt lariat, 5.0 with the m5r2. i wont be using the old shift ****. the markings have faded anyways :P
Old Aug 3, 2015 | 09:52 PM
88XLTLariat's Avatar
88XLTLariat
Try a slide hammer.
Blue Rebel's Avatar
Blue Rebel
Somebody glued it on. It should just pull off w/ a little effort.
Old Aug 3, 2015 | 09:53 PM
anthonym92's Avatar
anthonym92
i guess i could
Old Aug 4, 2015 | 04:24 AM
EPNCSU2006's Avatar
EPNCSU2006
Heat the metal shift lever
Old Aug 4, 2015 | 04:27 AM
Diesel_Brad's Avatar
Diesel_Brad
Pressed on. Pliers under the **** and then hit plies with a hammer
Old Aug 4, 2015 | 06:51 AM
dixie460's Avatar
dixie460
Big channel locks or hammer it off like Brad suggested. You didn't say what you're gonna replace it with but most aftermarket ***** have 3 allen screws in them to hold them onto the shift lever. These SUCK big time and will always be coming loose on you. I suggest you find one that doesn't use these, or find some other way to attach your new piece.
Old Aug 4, 2015 | 01:24 PM
anthonym92's Avatar
anthonym92
i got it off using the pliers and hammer that is harder to do than a frickin intake mani gasket :P also the one im replacing it with is suppose to be pressed on it seems and came with a glue or something....or it might be a lube to get it on since the new one is just as hard to get on as it was to get the old one off
Old Aug 4, 2015 | 07:53 PM
Mule420's Avatar
Mule420
Spit on ur **** lmao should come right off def glued on or sumthing . I've had them just slide off wen shifting I always replace
1984F2506.9
Jan 19, 2014 04:06 PM
bobaloo11
1983 - 2012 Ranger & B-Series
Feb 13, 2012 07:34 PM
RollBackTowTruck
Aug 19, 2009 08:52 AM
StrokeThis96
Apr 21, 2008 09:19 AM
Luckie117
Apr 30, 2005 07:06 PM
