Shift Knob Removal
Old Jan 16, 2014 | 06:47 PM
1984F2506.9's Avatar
1984F2506.9
Shift **** Removal
My truck has a 4 on the floor and for the life of me i cant figure out how to remove the shift ****. Ive tried twisting ive tried pulling the only thing i have not done is putting a torch to it. Is it glued on? Is the **** rubber covered metal?
Old Jan 16, 2014 | 08:05 PM
ctubutis's Avatar
ctubutis
Does it have a nut on the bottom that needs to be loosened?
Old Jan 16, 2014 | 10:16 PM
1984F2506.9
Nope ive tried all i could think of but nothings working
Old Jan 16, 2014 | 10:28 PM
ctubutis's Avatar
ctubutis
You don't say what year you have or even what transmission you have... assuming manual transmission with floor-mounted shifter...
1980-82 are threaded on, 1983-86 are pressed on; if the latter, just pull up & off but you'll likely have to pull HARD and maybe pounding with a mallet from the underside will help.
Old Jan 16, 2014 | 11:36 PM
1984F2506.9
ya its an 84 4 speed dont know what transmission that is. Ill try at it again tomorrow, thanks.
Old Jan 17, 2014 | 08:11 AM
f150xltlarait's Avatar
f150xltlarait
i hvae an 86 with a 4 speed and it just pulls off like the 4x4 ****
Old Jan 17, 2014 | 08:14 AM
BiGGreen350's Avatar
BiGGreen350
on my uncles 84 4 spd, we always just use the box end of a wrench that is the same size of the shifter, and then smack the wrench upwards with a hammer
Old Jan 17, 2014 | 03:21 PM
1984F2506.9
just got it off what i did was i took a flat head screwdriver and a hammer and hit the flat head under the shift **** to break the glue and it came right off. only took me a couple of minutes.
Old Jan 17, 2014 | 06:18 PM
bill06447's Avatar
bill06447
Any recommendation for adhesive to reattach the ****? Tired of my transfer case **** coming off in my hand ~Bill
Old Jan 18, 2014 | 04:42 PM
f150xltlarait
I put a plastic bag around the shaft then push the **** on and rip the extra away
Old Jan 19, 2014 | 03:54 PM
rowdyredneck's Avatar
rowdyredneck
I don't think they were glued on from the factory, its just a press fit. My transfer case **** was loose as well and all I did was wrap a small scrap of paper over the end of the lever before pushing it back on.
Old Jan 19, 2014 | 04:06 PM
ctubutis's Avatar
ctubutis
Correct; if there's glue there, likely some PO put it there.
anthonym92
Aug 4, 2015 07:53 PM
bobaloo11
1983 - 2012 Ranger & B-Series
Feb 13, 2012 07:34 PM
mrblonde108
Jun 29, 2010 11:36 AM
RollBackTowTruck
Aug 19, 2009 08:52 AM
StrokeThis96
Apr 21, 2008 09:19 AM
