How much explosives needed to remove shift knob?
Old Feb 11, 2012 | 03:51 PM
bobaloo11's Avatar
bobaloo11
How much explosives needed to remove shift ****?
Hi all,
I have a '94 Ranger w/5 speed and am trying to remove the shift ****. I cant figure out how it comes off. Is it pressed on? Glued? Welded? All of the above?
I could use some help here, please.
TIA
Old Feb 11, 2012 | 04:09 PM
93 mix 'n match's Avatar
93 mix 'n match
EDIT: wrong info...
Old Feb 11, 2012 | 04:15 PM
powersmoked's Avatar
powersmoked
Originally Posted by bobaloo11
Hi all,
TIA
it is just pressed on......there are splines on the stick and in the ****.......I ended up trashing mine when i took it off to do my clutch(I found out later I did not have to remove it for the clutch).....you can heat the crap out of it if you are not worried about trashing it ..I got a new one at the JY
Old Feb 11, 2012 | 07:22 PM
g_k50's Avatar
g_k50
The center cap on my old broken shifter **** in the 2001 model popped out with a flathead screwdriver. then the splines can be seen and the **** should come off without loosening any bolts or nuts.
I got a very nice replacement **** from Ford, fits good and feels like orginal.
Old Feb 13, 2012 | 07:36 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
Straddle the center console, one leg on each side. Grip the **** with both hands and pull straight up. Caution, the know will want to smack you in the nose when it comes loose. Reattach using super glue on the splines.
Old Feb 13, 2012 | 09:02 AM
MikeB 88's Avatar
MikeB 88
Maybe you can get a 2x4 and cut a slot in it just wide enough to slip around the stick and under the ****. Then wack the 2x4 with a dead blow.
Old Feb 13, 2012 | 07:34 PM
mbxmitch's Avatar
mbxmitch
I wish I had this problem mine just spins around and comes on and off as it wants
anthonym92
Aug 4, 2015 07:53 PM
1984F2506.9
Jan 19, 2014 04:06 PM
mrblonde108
Jun 29, 2010 11:36 AM
RollBackTowTruck
Aug 19, 2009 08:52 AM
3literranger
Mar 27, 2006 10:32 PM
