It's all timing
Old Sep 22, 2015 | 03:59 PM
BTFordGuy302's Avatar
BTFordGuy302
Not at the exact same time,but it would switch between exhaust and carb backfire
Old Sep 23, 2015 | 02:11 PM
BTFordGuy302
UPDATE*** I talked to ford guy at my trade school's auto department, his first question was on timing, and how I timed it, apparently I wasn't lining up the punch mark on the balancer right, there's a hole (which was what I was lining the punch mark up with) then there's a part that comes to almost a point. That's what I was supposed to be lining it up with, not the hole... It's still not firing up though... It sounds more like a misfire now, I'm going to check my fuel pressure and some other things with my fuel delivery, not ruling out a spark or timing issue all together quite yet, but at least now I'm on more of path to figuring it out hopefully lol
Old Sep 23, 2015 | 02:23 PM
Tedster9's Avatar
Tedster9
Double check you're at TDC on compression stroke when rotor is pointing to #1 plug wire at distributor?
Old Sep 24, 2015 | 12:54 PM
BTFordGuy302
It's definitely without a doubt at TDC, and yes, I have the rotor pointing to the #1 plug wire
Old Sep 24, 2015 | 01:11 PM
Tedster9's Avatar
Tedster9
To clarify or avoid confusion for others who may read this in the future - there are "two" possible top dead centers (TDC) ; one on the compression stroke, and one between the exhaust and intake strokes. For timing purposes we want the former, not the latter. Common error.
Old Sep 24, 2015 | 01:37 PM
BTFordGuy302
Correct, mine is on the compression stroke... Could it just be too much fuel like someone else said? I've verified I'm getting fuel, I've verified I'm getting spark, and the timing has to be right... I don't know what else it could be at this point....
Old Sep 24, 2015 | 02:06 PM
Tedster9's Avatar
Tedster9
Could be I guess. Pull a plug and check for excess fuel. Fuel soaked plugs can go "dead" too, fwiw. I doubt that's the problem though something to consider.
Start from square one. Maybe a compression test, ensure firing order is correct.
Old Sep 24, 2015 | 02:30 PM
BTFordGuy302
I did a compression test already, compression's not great, around 100 in all the cylinders except one, that one is around 70-75. That's good enough to run it though ain't it? Firing order is correct for a non ho pre 1995 302.
Fetruck86
May 29, 2016 08:42 AM
64'F100BobbySurfer
Jul 27, 2015 06:56 AM
x_man586
Feb 20, 2014 12:58 PM
montgomery7
23
Mar 1, 2010 07:53 PM
luke-gr
18
Nov 1, 2007 03:28 PM
