It's all timing
Old Jul 27, 2015 | 11:32 PM
BTFordGuy302's Avatar
BTFordGuy302
It's all timing
Hey guys, some of you know my 85/86/84 saga but for those of you that don't, here's the scoop! It's an 85 F-150, 302 engine, believed to be from an 86 Lincoln, converted it from tfi, to DSII, manual trans. Why it won't start? I'm fairly certain it's out of time, but I can't seem to get it just right. All the harmonic balancer has on it is a punch mark, I'm assuming this is what represents TDC, if anyone can verify that! When I turn the key, it'll cough, but not rapidly. It is not back firing out of the carb, so it's not 180 out... How do I pinpoint where EXACTLY "in time" would be? Seems like no matter where it is (referring to the distributor rotor) it's just enough out of time where it won't start...
Old Jul 27, 2015 | 11:42 PM
Tedster9's Avatar
Tedster9
Verify #1 cylinder at TDC, compression stroke.
Note location of rotor, should point just prior to #1 tower on distributor cap. Ensure firing order is correct for all wires, etc. if you do this, it should start or nearly so. Try adjusting the distributor slightly and try again. Once it fires use a vacuum gauge to set the timing.
Old Jul 28, 2015 | 12:02 AM
BTFordGuy302
Okay, thankyou I'll have to buy a vacuum gage, or rent one, all I have is a timing light on hand...
Old Jul 28, 2015 | 12:12 AM
Tedster9's Avatar
Tedster9
Well if you have a light already, that's one thing. A vacuum gauge works well though, and avoids some of the variables or unknowns.
Old Jul 28, 2015 | 02:46 PM
Franklin2's Avatar
Franklin2
Take the spark plug wire out of #1 cylinder, and put your finger over the hole to plug it off, and turn the engine over till air starts blowing out around your finger. Stop and slowly turn the engine the same direction with a socket till the mark comes around. If you have no pointer at all to go with the mark, you may have to take the valve cover off the pass side and verify where you are at by looking at the rocker arms on #1 cylinder.
You can get things mixed up on these engines if you use the wrong balancer with the wrong timing cover/pointer bracket.
Old Jul 28, 2015 | 11:56 PM
BTFordGuy302
Ok cool, thanks franklin! I'll mess around with it tomorrow and see what I can do!
Old Sep 21, 2015 | 02:00 PM
BTFordGuy302
Sorry it's taken me so long to respond to this! I got caught up in some other things that I had to knock out, like my sending unit not reaching the bottom of the tank, and my clutch release bearing was in backwards, so that was fun as well, but anyway! I did this and wasn't get much, just a weak cough... I then tried advancing the spark a bit, now it's coughing, and backfiring like crazy, but it STILL won't start... It's not backfiring out of the carb, so it's not 180 out... My buddy does a lot of work on engines and he's stumped also...
Old Sep 21, 2015 | 04:37 PM
bcamill's Avatar
bcamill
Might be too much fuel. It sounds like it is choking and then the back fire is coming out the exhaust. Were you able to identify TDC?
Old Sep 21, 2015 | 10:06 PM
BTFordGuy302
Yeah, I found tdc, that actually makes a lot of sense, I hadn't thought of that.... I'll tinker around with it, make some adjustments, then I'll post what I can get to happen!
Old Sep 22, 2015 | 05:15 AM
Ken Blythen's Avatar
Ken Blythen
There were two firing orders for 302's..........could it have been changed since it last ran?
Old Sep 22, 2015 | 01:37 PM
BTFordGuy302
To my knowledge, the firing order changed in 1995, there was only one before that correct?
Old Sep 22, 2015 | 01:53 PM
Peavey1986's Avatar
Peavey1986
If the engine is a h.o then it will have the 351 firing order. Be glad you don't have the ****ty efi ...
Old Sep 22, 2015 | 02:58 PM
BTFordGuy302
It's not ho, I ran the number on the old dizzy, it said 86 Lincoln town car, they didn't put the h.o. In those. That was a truck and stang thing... It was efi at one point, the p.o. Switched it to carb and did a real hack job on the wiring, all that in consideration I decided to just switch it over to DSII... Dunno what happened but I tried starting it before doing anything and, well, truck no go bang anymore... Won't cough either, gonna tinker with the timing...
Old Sep 22, 2015 | 03:08 PM
Franklin2's Avatar
Franklin2
Anyone can put a HO style cam in any 302 and that will change the firing order. You are correct, the 302 HO's were only in the mustangs(the truck's didn't have them either) and your LIncoln engine should have the regular firing order, but you never know sometimes.
Old Sep 22, 2015 | 03:56 PM
BTFordGuy302
Huh I didn't know that, when we had it backfiring, we did try the 351 firing order, it started backfiring out of the carb and the exhaust at the same time....
