Highboy specific brackets??
Old Jul 26, 2015 | 09:41 PM
highboyhouston's Avatar
highboyhouston
I have a question for some of you more experienced guys. I've come across some brackets for a front bumper, and I know it fits my 73 highboy, but not my 79 f150. Both are 4x4, and obviously one is a 3/4 ton, the other a half. Did ford make a specific bracket for the front bumper of these dents on highboy exclusively, and if so, are they worth anything?? Thanks in advance!
Old Jul 26, 2015 | 10:46 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The brackets were used to space the bumper forward to clear the leaf springs.
Old Jul 26, 2015 | 10:52 PM
75Three90's Avatar
75Three90
Highboys and other 4x4 dents have different width frames!
Old Jul 26, 2015 | 11:06 PM
Ranger1975's Avatar
Ranger1975
True, but only in the rear. The frame is the same from the rear cab mounts up to the bumper
Old Jul 26, 2015 | 11:30 PM
75Three90's Avatar
75Three90
Hmmmm I thought the front was different as well?
Old Jul 27, 2015 | 12:04 AM
Ranger1975's Avatar
Ranger1975
Nope, they are all the same. From the "Highboy" info thread
# Highboy Frames #
Highboys have a unique frame, not shared with other trucks. Like the F-350
frame, all Highboys have a narrow frame, which is 33.5-inches wide. Sixth
generation (1973-1979) F-series trucks had wider 37.5-inch rear frame
rails, except for the 1973-1977.5 Highboy frame and the 1973-1979 F-350
with 139-inch wheelbase. This frame rail width is measured directly
behind the rear bumper, from outside of rail to outside of rail. The F-350
frame was narrowed for duallies. The Highboy frame does not bend to the
left or right (unlike the other F-100, F-150, or F-250 frames), though it
does bend up and down to accommodate the cab. A front crossmember,
positioned just below the front bumper and visible while standing in front
of the truck, separates the Highboy frame from the bumpside F-350 frame.
No other truck had this crossmember. Since Highboys have a frame that is
different from other F-series trucks, Highboys require different beds than
other F-series. The Highboy frame was never used on another truck. ##############################################
So on the highboys the frames are 34in throughout , where as the non-highboy trucks widened to 37.5in in the rear.
Old Jul 27, 2015 | 12:15 AM
75Three90's Avatar
75Three90
# Highboy Frames #
So they are different up front
Old Jul 27, 2015 | 12:35 AM
highboyhouston
I know they're the same width up front, up until 78 or so. Does anyone know if these are worth anything? I can't seem to find anywhere that sells them. I have three sets now from parts I've been acquiring, but won't need two.
Old Jul 27, 2015 | 07:48 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Originally Posted by highboyhouston
Does anyone know if these are worth anything? I have three sets now from parts I've been acquiring, but won't need two.
I'd put one set on E-bay and see what they go for.
Old Jul 27, 2015 | 11:30 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
FTE classified section is a great place to post them. Ford Truck Enthusiasts Forums - Announcements in Forum : 1973 - 1979 F-100 & Larger F-Series Trucks
nine inch rear
Oct 24, 2012 11:35 AM
tomatu
Apr 15, 2012 07:24 PM
1977f150xlt
Jun 28, 2009 11:58 PM
bucks77ford
Apr 2, 2008 02:23 PM
m000996
Aug 4, 2006 07:40 AM
