1966 f350 headers ?
Old Jul 24, 2015 | 09:22 PM
tnfarmer67's Avatar
tnfarmer67
1966 f350 headers ?
I have a 1966 f350 with a 390 . I contacted summit racing and they show none for a f350. There was a comment on the headers I wanted that stated will not work because of the different steering box . Any pointers would be greatly appreciated
Old Jul 25, 2015 | 03:47 AM
jowilker's Avatar
jowilker
I don't play with the 350 arena, is yours a side mount or front mount engine? Is it a straight axle or I-beam?
John
Old Jul 25, 2015 | 07:07 PM
1972RedNeck's Avatar
1972RedNeck
A set for a '66 F250 4X4 should work as the frames and steering boxes are very similar. I run a set of THESE and they fit great.
Old Jul 25, 2015 | 10:21 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
It's a front mount as all 240/300/352: 1965 F100/250 4WD, 1965/66 F350, 1966 F250 4WD use the same engine mounting system as 1961/64's.
F350's didn't have Twin-I-Beam front suspension until 1967.
btw: There will be no applications for a 390 engine in any 1965/67 F100/350...since the 390 was introduced in 1968 F100/350's.
The only V8 available 1965/67: 352 2V
And, does the OP's truck really have a 390? On sale day, 352's magically become 390's!
Old Jul 25, 2015 | 10:22 PM
tnfarmer67's Avatar
tnfarmer67
It's a front engine mount and a straight I-beam front axle , and what make of headers are they ? My steering shaft pretty much goes through the floor not the flat fire wall too. I've never seen a 4x4 f250 so I'll take your word on it . I believe it uses a gremmer steering box , I'd like to add power steering but that will be later on .
Old Jul 25, 2015 | 10:23 PM
tnfarmer67's Avatar
tnfarmer67
It's a straight I beam axle
Old Jul 25, 2015 | 10:44 PM
NumberDummy
Originally Posted by tnfarmer67
My steering shaft pretty much goes through the floor. I've never seen a 4x4 f250 so I'll take your word on it.
I believe it uses a Gemmer steering box. I'd like to add power steering but that will be later on .
1961/64 F100/350; 1965 F100/250 4WD; 1965/66 F350; 1966 F250 4WD: The steering shaft goes directly into the steering gearbox.
Once the A/T (2WD only) or 3 M/T shift linkage (if so equipped) is disconnected from the column, the pitman arm is disconnected from the steering gearbox, the column and gearbox are removed as a one piece assembly.
Steering gearbox is the same: 1963/65 F100/250 4WD; 1965/66 F350; 1966 F250 4WD
F350's prior to 1967: No P/S can be swapped in from any other year Ford truck, so you'll have to buy an expensive aftermarket P/S kit.
btw: In 1941, Packard erected a new building on the north side of their assembly plant to assemble Rolls Royce-Merlin V12 aircraft engines, initially for the Brits.
After the war ended, Gemmer purchased this building. When Gemmer moved elsewhere, the plant stood empty until it was purchased recently by a Detroit firm that stages special events.
Old Jul 27, 2015 | 12:42 PM
candoo's Avatar
candoo
Just fought this battle. Hedman for 4 by 4 worked.
http://img.photobucket.com/albums/v4...pswqym5lbg.jpg
http://img.photobucket.com/albums/v4...psh9wivjoo.jpg
Old Jul 28, 2015 | 09:49 AM
candoo's Avatar
candoo
Checked my headers last night. Hedman 89120. I did have a new steering box plug made for extra clearance.
Old Jul 29, 2015 | 01:37 PM
tnfarmer67's Avatar
tnfarmer67
Number dummy i understand , on sale day they became 390's , the only thing ive seen to make me say 390 is the tag thats on the distributer hold down bolt has 390 ford on it . and Candoo , i see yours are stainless and the number you gave me are painted . really appreciate the help . its hot here in tn and im not in a hurry to finish the job till the heat breaks
Old Jul 29, 2015 | 01:41 PM
candoo's Avatar
candoo
They were painted, I had them ceramic coated. They are hedman 89120's painted black for shipping purposes only. I just recenty posted a vid of the truck with motor in it, check it out.
Old Aug 14, 2015 | 05:49 PM
tnfarmer67's Avatar
tnfarmer67
Candoo , I see what you mean about fighting the battle , it took me a while to get the drivers side in place ! But they fit and that's all that matter ! Thank candoo I really appreciate the help .
Old Aug 17, 2015 | 08:41 AM
candoo's Avatar
candoo
Glad to help
MNTBUGGY
Feb 17, 2019 08:43 PM
Trembler
Mar 3, 2018 11:13 AM
blisstruck
50
Apr 19, 2015 08:51 PM
69issofine
Dec 8, 2014 05:02 PM
dagomachining
15
Sep 22, 2013 01:45 PM
