Sponsored by: Real Truck
Brake issue. Need help
Old Jul 19, 2015 | 12:17 AM
Rkgfire's Avatar
Rkgfire
I have an 03 F350 4x4 dually. Was pulling hard left at low speed when braking (front). Replaced pads, calipers, rotors, hoses and tires. Still the same problem. You can feel the abs activate right before it almost locks up the left front brake (basically will pull the steering wheel out of my hand). Any help would be greatly appreciated. BTW the abs light does not come on.
Old Jul 21, 2015 | 10:49 AM
droldsmorland's Avatar
droldsmorland
Disconnect the ABS wire on that side see if it cures it. That will tell you it is an ABS fault. Could be the sensor the wiring or the reluctor/tone ring
Old Jul 21, 2015 | 11:06 PM
Rkgfire's Avatar
Rkgfire
droldsmorland: Thanks for the tip. Actually disconnected the opposite side and it went away. Replaced the vss wiring and that gave me an abs light and the problem returned. Long and short of it was a bad wheel bearing. New hub assemblies (both sides) and put her back together. No abs light and no pulling so no problem. Chunk of change so the wallet is a bit light this week. Thanks again.
Bluef2.5.0
May 28, 2019 05:17 PM
edsheridan
Aug 25, 2014 02:39 PM
Riskyguy
2004 - 2008 F150
Jul 20, 2014 01:49 PM
jvc100
Nov 8, 2004 11:45 PM
AllFords1022
Jan 8, 2004 01:50 PM
