how to test injectors?
Old Jul 30, 2003 | 11:18 PM
dbuck50's Avatar
dbuck50
Is there any way to test whether you have a stuck open injector while they are installed? Haynes doesn't cover this one...
93 f150 5.0 4x4
Old Jul 31, 2003 | 12:16 AM
Scooter29's Avatar
Scooter29
Hey there dbuck50 and welcome to FTE! I have a couple of questions. Are you sure you have injectors, throttle body? I've checked the Chilton's and it only has removal and replacement. I know there is a port to check for fuel pressure before the injectors or TB, but that won't help you locate the stuck one.
The Chilton also shows only 4 injectors on the V-8 engines.
If there are no other individual ports to connect a fuel pressure gauge up to at each injector, It looks like you'll have to pull them all. I would start with the one you think will give you the most trouble getting out. It's usually the culprit. These things can never be easy!!
The instructions are quite extensive, so it looks like you'll be on top of the engine for quite awhile. Good luck and get back with us on the results. Talk with you later....
Old Jul 31, 2003 | 01:50 AM
ludis's Avatar
ludis
Put a fuel pressure gage on it. Start the engine and shut it off. It should hold pressure for a _long_ time. Like overnight, but if the pressure hasn't dropped much in several minutes, you should be OK.
To find which of the eight leaks, you'll have to pull the injectors.
Old Jul 31, 2003 | 12:08 PM
c_rossman's Avatar
c_rossman
check the resistance with a VOM each injector should be about 12 ohms
Old Jul 31, 2003 | 01:35 PM
jrs_big_ford_f150's Avatar
jrs_big_ford_f150
If you had an injector stuck open, would cause one cylinder to run real rich. If you pulled your spark plugs out and inspect them, you will most likely find the one cylinder with the bad injector.
Old Jul 31, 2003 | 01:37 PM
dbuck50's Avatar
dbuck50
What would the plug look like compared to the others? I just replaced them, would that affect what it looks like?
Old Jul 31, 2003 | 02:17 PM
jrs_big_ford_f150
Normal lookin plugs have light gray or tan colored deposits on them. I would imagine the bad one would look wet, fouled. Something to that extent. You will most likely tell right off that it don't look like the others.
Old Jul 31, 2003 | 02:49 PM
drool's Avatar
drool
There are shops you can send your injectors to and have them checked., Costs something like $25 each. Better than shotgun replacement of the whole set which is what some places like to do.
Old Jul 31, 2003 | 11:08 PM
dbuck50's Avatar
dbuck50
OK, I tested the fuel pressure with a guage and it registered 31lbs. When I shut the engine off, it took about five minutes for it to lose about 5lbs...so I am assuming that i don't have any injectors stuck open. Make sense?
Old Jul 31, 2003 | 11:31 PM
jrs_big_ford_f150
You most likely have a leak. Time to find it. I would definatly pull the spark plug to see if it is an injector. If it ain't an injector then good luck finding it.
Old Aug 1, 2003 | 08:28 AM
dbuck50's Avatar
dbuck50
actually, most of the plugs look wet with oil around the threads...that can't be good.
frederic
Garage & Workshop
May 28, 2007 01:57 AM
javaelina
Nov 10, 2004 10:57 AM
alarsso444
17
Jul 29, 2004 03:25 PM
ftrain
May 24, 2002 06:51 PM
