injector test
Old Nov 10, 2004 | 10:31 AM
javaelina's Avatar
javaelina
injector test
How to see if injectors are working while cranking engine. 89 F150 5.0
Old Nov 10, 2004 | 10:49 AM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
You can get a noid light to check the electrical signal to the injector. If the engine is not starting and the plugs are wet the injectors are probably working.
Old Nov 10, 2004 | 10:51 AM
fefarms's Avatar
fefarms
Run a KOEO test and verify that the PCM is capable of controlling the check engine light. It should flash error codes or the "1-1" or "1-1-1" pass code. If the PCM doesn't work, the injectors won't work.
If the above looks OK, to check the injectors, you need to connect a 12 volt test light between each of the two wires going to one injector, and the battery negative post. As the engine cranks, one wire should indicate a steady voltage through a steady test light, and the other wire should indicate a pulsing voltage by flashing the test light. (With the engine not cranking, both wires should show a steady 12 volts).
Old Nov 10, 2004 | 10:57 AM
javaelina's Avatar
javaelina
Thanks that is what I needed to know
tpc3
Dec 13, 2013 08:36 PM
danielwd
1983 - 2012 Ranger & B-Series
Jan 2, 2011 10:18 PM
turbill
Dec 22, 2010 06:59 PM
SAltonS
Dec 18, 2009 08:36 PM
Nathan
Aug 5, 2001 08:58 PM
