Panel Removal help request
Old Jul 11, 2015 | 01:04 PM
jonrjen's Avatar
jonrjen
I know that to remove the lower knee panel under the steering wheel all that has to be done is to pull it off and the attachment snaps will pop free.
However, How do I go about removal of the dash panel to the left of the steering wheel? This would be the narrow panel that also houses an ac vent, headlight **** and I believe it is the adjustable pedal control.
Thank you for your assistance once again,
Jon
Old Jul 11, 2015 | 08:56 PM
sgrol's Avatar
sgrol
I think you can grab the top front of the panel (next to windshield) and lower part of panel and pull straight back. Held in with friction clips.
Old Jul 11, 2015 | 09:00 PM
jonrjen's Avatar
jonrjen
Do I need to pop off the ac vent trim ring or remove the **** from the headlights pull or anything?
Old Jul 11, 2015 | 09:06 PM
sgrol's Avatar
sgrol
Just tried mine again and it did not move. I can't remember if I removed dash bezel next to it to uncover screws or not. Sorry, I'm of little help. I have had it out but don't remember exactly how.
Old Jul 11, 2015 | 11:09 PM
Hunter40's Avatar
Hunter40
Ince you pop off the one under the steering wheel you will see one or two bolts holding the left side on. Remove them, then it will pull right out. No need to remove the ac vent trim. This is actually done after the panel is off by the way.
Hunter40
Old Jul 12, 2015 | 07:43 AM
jonrjen's Avatar
jonrjen
Excellent, thank you to all who replied.
Bigdon68
May 16, 2018 12:13 PM
Budlight592
6.7L Power Stroke Diesel
Feb 28, 2012 09:41 AM
a1awind
Sep 18, 2010 08:18 AM
88-150
Feb 9, 2010 03:32 AM
