Removing Dash Panel below steering wheel
Old Jan 27, 2017 | 07:07 AM
Bigdon68's Avatar
Bigdon68
Any secrets to removing this panel. I am starting the install for my auxiliary fuel tank -- but first comes the gauge and the computer controller box.
I need to remove the dash panel.
Then I need to find the dimmer switch wire. In the past it has been the purple with gray stripe.
Any help would be appreciated.
Bigdon68
Old Jan 27, 2017 | 07:26 AM
charlesweaver3's Avatar
charlesweaver3
I am interested in this as well.
Old Jan 27, 2017 | 08:20 AM
EightySecond's Avatar
EightySecond
When I first picked up my truck that panel wasn't fully snapped in on the lefthand side. I just pushed it and it seated. So I assume with a little gentle pulling/ prying it will just pop back off. The spot I am talking about is the top horizontal edge,
Old Apr 16, 2018 | 06:53 PM
BronzefireAL13SD's Avatar
BronzefireAL13SD
Bump. Did you ever get this panel off? is it nothing more than some push clips? I need to remove mine but have bad luck with breaking plastic trim pieces lol.
Old Apr 16, 2018 | 07:04 PM
csetheridge1's Avatar
csetheridge1
Just grab it below the steering wheel and pull out on it. It is hinged on the bottom.
Old Apr 16, 2018 | 08:47 PM
azguy741's Avatar
azguy741
I just brought my new 2017 F250 home and had to pull that panel off so I could access the trailer brake controller pigtail in the dash, and then install the trailer brake controller from my the 08 Ford that I traded in. Simply put, the panel below the steering wheel has push clips on the sides and screws inside the bottom where it is hinged. . I got the plastic panel off by carefully prying, with my fingers, where the rubber shield or "gasket" is, between the panel and the steering assy. Then worked my way around and down each side, using my hands. Wasn't hard to remove but if you horse it you may break it. Just go easy. That panel is backed up by a metal support that you may or may not need to remove for better access. It has 10mm hex heads holding it and the plastic panel, where the plastic panel is "hinged".
By the way, LOVE the truck so far.
Old May 16, 2018 | 12:13 PM
cdk888's Avatar
cdk888
Easy... adding an image
jonrjen
6.7L Power Stroke Diesel
Jul 12, 2015 07:43 AM
outbackf150
2004 - 2008 F150
Apr 16, 2014 08:01 PM
Budlight592
Feb 28, 2012 09:41 AM
