What do I have - 95 or 130 amp alternator?
Old 07-06-2015, 04:45 PM
kabcpapc's Avatar
kabcpapc
kabcpapc is offline
The truck is a 1997 F150 4.6L auto 2wd XLT supercab. I ordered it with the trailer towing package. How can I find out whether I have the 95 or 130 amp alternator? The MSRP window sticker has no mention about the alternator.
Old 07-06-2015, 08:18 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
I thought the 130 had a 8 rib pulley and the 95 amp had a 7 rib pulley (belt) ?
Old 07-06-2015, 08:20 PM
steve(ill)'s Avatar
steve(ill)
one e-bay post
<TABLE class=specs><TBODY><TR><TD class=title colSpan=2>Specifications:</TD></TR><TR><TD>Unit Type</TD><TD>Alternator</TD></TR><TR><TD>Part Type</TD><TD>UNIT</TD></TR><TR><TD>Voltage</TD><TD>12</TD></TR><TR><TD>Rotation</TD><TD>CW</TD></TR><TR><TD>Amperage</TD><TD>130</TD></TR><TR><TD>Clock</TD><TD>10</TD></TR><TR><TD>Pulley Class</TD><TD>S8</TD></TR><TR><TD>Regulator</TD><TD>IR</TD></TR><TR><TD>Fan Type</TD><TD>IF</TD></TR><TR><TD>Brief</TD><TD>FORD E & F SERIES TRUCKS 1997-98
8-GROOVE PULLEY 59mm OD</TD></TR></TBODY></TABLE>
Old 07-06-2015, 09:11 PM
cyclone-429's Avatar
cyclone-429
cyclone-429 is offline
This one is easy!
Old 07-10-2015, 10:52 AM
kabcpapc's Avatar
kabcpapc
kabcpapc is offline
Thanks guys. Based on the measurements mine was a 130 amp. Got a new one at Advance Auto for $151.50 including tax. Took about 3 hours to put in including time to get all my tools needed out of the shop building, hooking up a big fan to keep me cool, waiting out a 15 minute rain delay, then putting everything away. Moving some parts under the hood out of the way didn't take long. But the tensioner took longer than I expected because the 1/2" breaker bar I was going to use couldn't be put in the square hole due the metal fan blades in the way. So I improvised. I used a short 1/2" stubby rachet that I could insert in the hole. Then I got a deep socket that would fit over the handle, attached several extensions to get it up high enough to grab and it worked. The alternator was tight getting out but I finally got it out. Install took considerably less time. I was charging the battery (it was a brand new one) as I was doing my work so it would have a full charge. Cranked it up and took the truck back to Advance Auto to take the core and have them retest everything. Everything checked out so I'm happy. Sore from bending over the front of the truck but still happy.
Old 07-10-2015, 01:16 PM
steve(ill)'s Avatar
steve(ill)
I don't understand why MOST vehicles are designed like that . Tensioner is a good idea, square drive is a good idea.. then put the fan or radiator shroud in the way so you only have 3/4 inch clearance to install a 1 inch thick breaker bar !!!!
Old 04-25-2019, 12:45 PM
dremtofford's Avatar
dremtofford
dremtofford is offline
so the 130 amp has two holes in between the ribs and the 95 amp has 4 holes?
Old 04-25-2019, 06:27 PM
formerjeepguy's Avatar
formerjeepguy
formerjeepguy is offline
No, the 130 amp has two holes in between the ribs and the 95 amp has 4 holes as you can clearly see in the picture.
The following users liked this post:
Old 04-25-2019, 09:08 PM
steve(ill)'s Avatar
steve(ill)
isn't that what he just said ?
Old 04-26-2019, 08:40 AM
formerjeepguy
Given the clarity of the picture, my response was as necessary as his question.
Old 04-27-2019, 10:39 AM
dremtofford
i couldn't see the picture yet my computer is slow.
Spaz1461
Large Truck
01-30-2018 10:38 AM
marv02
13
06-22-2017 10:39 AM
mustang9701
01-06-2013 04:19 PM
Dyllan78
08-11-2012 08:50 PM
Justin's Green Truck
1997 - 2003 F150
01-20-2011 08:45 PM
Quick Reply: What do I have - 95 or 130 amp alternator?
