Alternator Amps
Old Jun 20, 2017 | 10:33 PM
marv02's Avatar
marv02
Alternator Amps
How can I tell which Alternator do I have 1997 F250 HD 7.5 auto E4DO.
95 amp or 130 amp.
Old Jun 20, 2017 | 11:20 PM
mrollings53's Avatar
mrollings53
The cooling holes in the front of the case come in groups of four for the 95 amp alternator, and groups of two for the 130 alt.
Old Jun 21, 2017 | 08:23 AM
marv02's Avatar
marv02
Which Alternator is this one
Which Alt is this one.
Old Jun 21, 2017 | 10:59 AM
White 97 xlt's Avatar
White 97 xlt
95 AMP .........
Old Jun 21, 2017 | 11:08 AM
marv02's Avatar
marv02
Hum do you think the 95 AMP can run a 8 AMP electric Fan
Old Jun 21, 2017 | 12:16 PM
TexasGuy001's Avatar
TexasGuy001
My thoughts are that the 95 amp alternator is barely capable of keeping up with a stock electrical system. This is especially true when AC, lights, wipers, radio, etc are on at the same time.
Old Jun 21, 2017 | 12:33 PM
Tedster9's Avatar
Tedster9
One thing a lot of folks neglect is the cables themselves and ground connections, including the alternator itself to the block through the brackets. Any corrosion, often invisible is more than enough to cripple any alternator. It won't be noticeable at idle but under load it will choke. Charging systems must have clean and tight electrical connections throughout or the battery will never charge to 100% and alternator won't provide anywhere near the current it's rated for. Before swapping out OEM alternators check the voltage drop through grounds and positive cables. Be sure you're getting what you paid for.
Old Jun 21, 2017 | 01:03 PM
Briansshop's Avatar
Briansshop
Might,might not. I have 2 fans,and big fuel pump on my Lightning and the the 95 amp was dipping to 12v at idle. A 130 amp was good.
Old Jun 21, 2017 | 01:17 PM
Azryael's Avatar
Azryael
What's the highest amp alternator that's a direct fit for our trucks, be it diesel or gas?
I don't mind running some thicker gauge wire to accommodate the increased juice, so that's not a big issue.
Mine had recently been replaced before I bought the truck, so I should be good for a while, but it looks like a parts-store rebuild or new unit, and we all know those tend to croak on diesels. Just posturing for the future
Old Jun 21, 2017 | 03:56 PM
marv02's Avatar
marv02
I am wanting to wire in the electric Pusher fan to blow on the A/C condenser at HWY speeds the A/C works great but at stop or stop and go traffic not so we'll just trying get some more air blowing across the condenser during these times.
It would be great if I could figure out so it only kicks on at speeds lower than 30 MPH driving but baby steps for now.
I don't think the electric fan needs to be running at HWY speeds.
Old Jun 22, 2017 | 05:39 AM
mrollings53
To be honest anything in front of the radiator is going to do more harm than good.
Some standard questions when it comes to cooling performance:
What is the condition of your fan shroud? Do you have a fan shroud?
Does the fan clutch work properly?
Does your A/C system need to be serviced anyways?
Are the fins straight on the radiator and condenser? Are they clean and free of debris?
There are a lot of other things that effect cooling performance that should be addressed before considering modifying a vehicle.
Old Jun 22, 2017 | 06:56 AM
marv02's Avatar
marv02
Yes I have a Fan shroud it in great condition
Yes the clutch fan works good.
The A/C is a R-12 system and it works and if could have it serviced I would the A/C out 1992 truck.
The fins are mostly straight there some bent ones.
Like I said the A/C works great as long there air blowing through it.
A/C works while at a stop or in traffic just trying get to perform better when I am stopped or in slow moving traffic.
Old Jun 22, 2017 | 10:34 AM
marv02's Avatar
marv02
Did some asking around and digging there is places that still have R-12 but it expensive.
And they also make a new type of R-12a that will mix with the old R-12.
And they also claim the R-12a will mix with R134 and make the system run cooler also.
Duracool® Technical Information - FAQ'S
Old Jun 22, 2017 | 10:39 AM
rla2005's Avatar
rla2005
I buy 12 ounce cans of new R12 on E-Bay. If I can avoid it I do not like using R12 variants. I've done it, it worked but not my favorite way to go.
Once the initial doom and gloom of R12 production ceasing the prices have come back down to earth that make sourcing small quantities online cost effective IMHO.
HaydukeLives
Aug 6, 2018 07:12 AM
TAT2DUP81
Mar 2, 2018 02:15 PM
kyle j
Jan 28, 2013 09:51 PM
Mazda_man
1983 - 2012 Ranger & B-Series
Nov 8, 2004 10:27 PM
judge1971
Electrical Systems/Wiring
Jun 25, 2004 02:05 PM
