new alternator??
Old Jan 5, 2013 | 11:34 AM
mustang9701's Avatar
mustang9701
new alternator??
i got my new DC alternator today. i notice the pulley size is different. is this ok or normal or am i to change the pulley.
Are there benefits to a smaller pulley?
Old Jan 5, 2013 | 11:39 AM
r2millers's Avatar
r2millers
It turns faster and will ultimately create more amp output at lower rpms. Unless the tensioner won't tighten the serpentine belt properly, I don't see any reason to worry about it.
Old Jan 5, 2013 | 03:02 PM
f-350 turbo's Avatar
f-350 turbo
That is normal. What model did you get.
Old Jan 5, 2013 | 05:42 PM
mustang9701
185 amp, not sure of model just said OEM
Old Jan 5, 2013 | 06:07 PM
TJK1's Avatar
TJK1
How long did it take for you to get it? I just ordered the same one last week
Old Jan 5, 2013 | 06:21 PM
BLADE35's Avatar
BLADE35
Hell Ya LEAVE the Smaller Pulley On it
Thats part of HOW it will Generate MORE Power at Idel
If the belt slips then you mighrt be Due for Belt and Or Belt Tensioner
Old Jan 5, 2013 | 06:36 PM
69cj's Avatar
69cj
Or possibly the spacers?
Old Jan 5, 2013 | 07:00 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Are spacers used with the OEM style alternators? Thought was just the XP billet alternators that needed spacers.
FWIW my 3G has the smaller pulley and no spacers and works just fine.
Josh
Old Jan 5, 2013 | 09:01 PM
BLADE35's Avatar
BLADE35
Josh
Oh Really Thats Cool
Old Jan 5, 2013 | 09:23 PM
Bullitt390's Avatar
Bullitt390
The OBS 7.3 Powerstroke had the 3G with small pulley.
Even the stock 6G could benefit from the small pulley.
Josh
Old Jan 5, 2013 | 11:48 PM
Fulthrotl's Avatar
Fulthrotl
that is why there are spacers, so the OUTSIDE edge of the
pulley is the same distance away, so the belt tensioner
can maintain correct tension.
measure the two pulleys, take the difference in diameter,
and divide it by two.....
that is the thickness of the spacers.... mostly...
the smaller pulley spins faster, and generates more
current at engine idle.... their 270 amp unit does
200 amps output at idle..... ya gotta spin it, there
is no free lunch.
Old Jan 6, 2013 | 08:50 AM
mustang9701
i ordred mine dec 22, just recieved it on 1-5, the two holidays in between didnt help matters so im happy with the time. i imagine where you order from matters too. i got it from dc directly
Old Jan 6, 2013 | 08:53 AM
mustang9701
its on and belt is tight and no spacers needed or even came with it. the pulley looks about the same size as my das's 7.3. SGII says 14.2 at idle.
Old Jan 6, 2013 | 01:53 PM
BLADE35's Avatar
BLADE35
Sounds Good So Far
They did recomend a Wire upgrade to between the Alt and the Passengerside Battery
Here is Mine Also Note this Red Wire also has a Fusable Link in it (Its the Peice of Grey Wire right at alt end)
And some more pics below
Ford Truck Enthusiasts Forums - BLADE35's Album: DC Power Alternator & Wire Upgrade
Old Jan 6, 2013 | 02:39 PM
mustang9701
hmm i did not see anyhthing about a wire upgrade. what guage should i use? and whats its purpose?
