1978 - 1996 Big Bronco
1990 Bronco Window Washer Pump
Old 07-02-2015, 01:02 PM
g_k50's Avatar
g_k50
g_k50 is offline
I assume a lot of people with Broncos have the same problem with their window washer pump and reservoir. I haven't used mine in forever because it leaks out and I didn't have time to look into the issue. But now I've the time and here's what I'm finding out.
I bought a new reservoir and a new pump from Oreilly's and when I put them together and filled up the reservoir it still leaked.
So I'm going to try putting some clear silicone sealant around the pump and see if that solves the leak issue.
Anyone else tried something similar or something different?
Am I pushing the motor too far into the reservoir?
I did use graphite lubricant per the instructions, doesn't seem to make any difference.
Old 07-03-2015, 07:37 AM
tigerhawk_212's Avatar
tigerhawk_212
tigerhawk_212 is offline
It's been a long while but I recall this being very simple and mine didn't require any additional sealing.. but then again I was using an original reservoir with an aftermarket pump. Wonder if it's possible that it leaks because of inconsistencies in the aftermarket parts? Just a guess.
Old 07-03-2015, 09:13 PM
My4Fordtrucks's Avatar
My4Fordtrucks
My4Fordtrucks is online now
Received 1,380 Likes on 1,089 Posts
Had my '87 since Nov of '95 and the washer reservoir has never leaked. No problems with my '94 either. Sorry but not sure why it won't seal up.
the5schlueters
04-07-2013 03:42 AM
pdqford
1997-2006 Expedition & Navigator
04-01-2008 11:19 AM
torquemeister
01-30-2006 06:14 PM
Glackowitz
03-12-2004 10:59 PM
Red Raider 4x4
10-30-2003 09:46 PM
Quick Reply: 1990 Bronco Window Washer Pump
