ND Help Please - Steering Boxes
Old Jun 28, 2015 | 02:54 PM
1964FORDTUF's Avatar
1964FORDTUF
Hi Bill -
I've acquired some 61-66 items that I am slowly wading through. I have 3 one piece (steering shaft direct into box) manual steering boxes. One of them has casting numbers that match exactly what I took out of my 64 4X4 for the restoration period. Both mine and the one I just acquired have 5DC62 in the casting beneath the word GEMMER. Looking at some old posts, you once posted:
5DC62 = C3TZ-3504-W .. Steering Gear Box.
1963/66 F350 model 84 Chassis & Cowl Open Drive-Away (no windshield, no cab).
Model 84 steering gear housing, steering shaft and worm are different than F100/350 model 81 conventional cab.
C3TZ-3524-N shaft & worm F100/350 81 conventional cab: 40 7/16" long / C3TZ-3524-R shaft & worm F350 model 84: 45 7/16" long.
I haven't measured the shafts yet to compare what came out of my F250 but the above info would seem to indicate my box is not correct for the F250... It sure seemed to fit OK in the truck...Do you know what the correct Ford PN is for the 64 F250 4x4, and possibly what the casting number would be? Thanks. The other 2 units I have are: C3TR 3550A (not a Gemmer?) and the other Gemmer has 4DC51 casting. I can get a few pics once the cloud warms up..lol.
Old Jun 28, 2015 | 06:08 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 1964FORDTUF
Hi Bill -
C3TZ-3524-N shaft & worm F350 84 Chassis & Cowl: 40 7/16" long
C3TZ-3524-R shaft & worm F100/250 4WD (see apps below) & F350 model 81: 45 7/16" long.
C3TZ-3504-S.. Steering Gear Box (no ID number listed) / Obsolete
C3TZ-3524-R .. Steering Shaft & Worm (no length listed) / Obsolete
Applications: 1963 F100/250 4WD & F350 (Conventional Cab, body style 81) from serial number 380,001 / 1964/65 F100/250 4WD & F350 (Conventional Cab).
Upper pic, column left-center: 81 Conventional Cab.
Lower pic, column left-upper: 84 Open Drive-Away Chassis & Cowl.
Old Jun 29, 2015 | 02:15 PM
1964FORDTUF
Thanks ND...something aint quite right. Both the box / shaft I have are the shorter 40" ones, and the guy I got the latest box from swears it came from a 63 he owned for many years...Anyway, Ive got two of the same and the one that came out of my truck worked perfect, so now I have a spare. Thanks again.
BenPhil
Oct 7, 2013 12:48 PM
Voodoo66
Apr 3, 2010 07:46 AM
Roger Bell
Oct 9, 2009 01:41 PM
phampton428
Jul 25, 2009 09:44 AM
BarnieTrk
Jul 4, 2009 08:13 AM
