1964 Steering Gear Box
(This is a TYPICAL problem with Ford steering gears) and can't be adjusted out.
I do have manual steering boxes from '54 and '57 F100's...my question is would either one of these work for my '64?
No.
Fits: 1961/64 F100/250 2WD.
Why would you want to install another used steering gear?
It will not be any better....it could be worse.
NEW old stock genuine Ford parts can be found for your present gearbox, I've done this for members here dozens of times.
2) C2AZ3571A .. Steering Shaft Bearing.
GREEN SALES in Cincinnati OH has FOUR: 800-543-4959
ANTIQUE AUTO SUPPLY in Arlington TX has TWO: 817-275-2381.
PARTS INTERNATIONAL in Farmers Branch TX has THREE: 888-727-0418.
BOB ALLEN FORD in Overland Park KS has THREE; 800-676-0675.
TISON MOTOR SALES in Estill SC has THREE: 803-625-2551.
2) C2AZ3552A .. Steering Shaft Race.
GREEN SALES has FOUR.
ANTIQUE AUTO SUPPLY has THREE.
PARTS INTERNATIONAL has FIFTY.
BOB ALLEN FORD has THREE.
TISON MOTOR SALES has SIX.
1) B8A3576A .. Sector Shaft Bushing
ANTIQUE AUTO SUPPLY has ONE.
TISON MOTOR SALES has ONE.
JST AUTOMOTIVE in Lebanon TN has ONE: 615-443-3086.
KLIMESH MOTOR SALES in Calmar IA has ONE: 563-562-3241.
LYLE'S FORD-MERCURY in Eagle Grove IA has TWO: 800-397-6319.
1) C3AZ3581A .. Sector Shaft Seal
GREEN SALES has 113.
PARTS INTERNATIONAL has 14.
1) C7OZ3591A .. Housing Gasket
GREEN SALES has 84.
PARTS INTERNATIONAL has 50.
Usually just replacing these bearings, races and the bushing will make a world of difference.
You can install just these parts and see what happens.
If the play is still apparent, then you will have to replace the steering shaft and the sector shaft.
1) C1TZ3524A .. Steering Shaft (includes worm gear)
GREEN SALES has TEN.
BOWMAN FORD SALES in Bowman ND has ONE: 701-523-3257.
1) B8A3575A .. Sector Shaft
GREEN SALES has EIGHT.
ANTIQUE AUTO SUPPLY has TWO.
This is a very simple box to work on...I've overhauled dozens like this.
If a klutz like I can do...anyone can.
I will also be rebuilding my steering box soon thanks for the part numbers. Iwas looking at the service manual and I don't see what kind of oil or grease it should use. I thought I'd ask what you used in your rebuilds?
Randy
This is grease and since it comes in a cardboard tube, it ain't gear oil!
You should be able to buy this at any autoparts store because Ford has used the same stuff for decades.
