Wiring
Old Jun 28, 2015 | 01:31 PM
wndsofchng06's Avatar
wndsofchng06
Wiring
What book do I need to look for to get the wiring diagram? I'm sorting out the PO's nest of wires that are tapped into various spots and trying to find where a few stock wires go that are just hanging loose. I also need to find the coil resistor. I have 12v at the switch and nothing at the coil.
Thanks
Old Jun 28, 2015 | 03:02 PM
arctic y block's Avatar
arctic y block
Any repair manual from your local parts store for
your year and model truck. Or look on E-Bay for
original manuals. Or get a CD Manual from I can't
remember where right now. But when the Gurus
come back on line Monday at work they can Tell
ya where to get the CD. Mainly I am just bumping
your post back to the top so maybe it will get looked
at more.
Old Jun 28, 2015 | 04:14 PM
daveengelson's Avatar
daveengelson
Posting couple pic's of 65/66 wiring diagram from Jim Osborn Reproductions for $7, found the manual helpful. Not sure if the Ford Master Catalog CD has wiring diagram; if so, may want to go that route for approx. $24 and it covers the just about every thing; including parts catalog, sheet metal description, etc.
Old Jun 28, 2015 | 04:25 PM
wndsofchng06
Awesome..... You don't happen to have the one with the coil on it do you?
Old Jun 28, 2015 | 04:49 PM
daveengelson
This is the only pic I have in photo storage but will try and locate the manual to determine if there's a better view of the circuit. Unfortunately unable to enlarge to the point you can make out the info in the box with the wire number and color code; perhaps another member can provide a better view?
Since installing Duraspark ll electronic ignition I tapped into the resistance wire which on my 65, if recall correctly, is a pink wire located behind the dash near the ignition switch??
Old Jun 28, 2015 | 04:53 PM
wndsofchng06
That's perfect. I can read it. #16 is red and green. So I have the right wire on both ends, just got to find that resistor in the dash somewhere!
Old Jun 28, 2015 | 04:56 PM
daveengelson
Edited previous thread after your comment; when I swapped points for E.I., I tapped into the resistance wire, on my 65 it is a pink wire located under the dash near the ign. switch.
Old Jun 28, 2015 | 05:00 PM
wndsofchng06
So I need the red and green wire on the start and pink on the "run" setting?
Old Jun 28, 2015 | 09:37 PM
F-ONE's Avatar
F-ONE
The 63 used a resistor or ballast wire. The only other resistor I know of is the dash resistor that drops the voltage to the gauges.
Old Jun 28, 2015 | 09:59 PM
wndsofchng06
OK mine definitely has that under the dash!
Old Jun 29, 2015 | 05:17 AM
wndsofchng06
But it also has a red and green under the dash. I don't see anything listed as red and green except the coil....
Old Jun 29, 2015 | 07:24 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C0LF-12250-A .. Resistor Wire-Ignition Coil (Motorcraft DY-37) / Obsolete ~ Available NOS & from auto parts stores.
61.49" long / Color coded pink / 1.30/1.40 ohms resistance / #20 gauge wire.
Applications: ALL 1960/70 FoMoCo vehicles.
No such thing as a "dash resistor."
B9MZ-10804-C .. ICVR-Instrument Cluster Voltage Regulator (Motorcraft GR-508) / Obsolete ~ Available NOS & from auto parts stores.
Misc. applications: 1961/66 F100/1100 / 1965/66 Mustang / 1966/77 Bronco.
Old Jun 29, 2015 | 07:26 AM
wndsofchng06
Thanks. Pink wire just wasn't hooked up. They have it hooked to a red wire with a green stripe, which is also shown as the coil on the diagram.... So I'm guessing some where in this mess, is a plug at the other end of the red and green wire that the pink wire plugs into....
Old Jun 29, 2015 | 07:34 AM
NumberDummy
Thanks. Pink wire just wasn't hooked up. They have it hooked to a red wire with a green stripe, which is also shown as the coil on the diagram....?
Only one resistor wire is required, it seems your truck has two.
D1AZ-12250-A .. Resistor Wire-Ignition Coil (Motorcraft DY-184-A) / Obsolete ~ Available NOS & from auto parts stores.
60" long / Color coded red with green stripes / 1.30/1.40 ohms resistance / #16 gauge wire.
Applications: 1971/73 misc. FoMoCo vehicles.
Old Jun 29, 2015 | 05:36 PM
wndsofchng06
Figured it out! There was a little single socket plug with a red and green wire back in the dash that the pink resistor wire plugs into....yay!!!
b_swift72
Dec 3, 2015 08:02 PM
Carmax
Nov 17, 2015 10:32 AM
1958fun
Nov 24, 2010 01:18 PM
jjsmoker
Feb 23, 2010 10:24 AM
Ron
Electrical Systems/Wiring
Jul 10, 1999 07:44 PM
