Steering Coupling Help
I have a 65 with manual steering and automatic transmission.
I am posting four pictures here:
https://picasaweb.google.com/jenphil...IrSkMSTiuOnGw#
I got the old coupling out (last two pictures) and can get the new coupling on the steering box (first picture). But I cannot figure out how to get the 12 point 7/8ths screw through the steering coupling once it is on.
It appears to be catching on the threads. You can see the arm of the steering box in the second picture and hopefully you can also see both grooves.
It would appear that the intention is for the screw to ride in the groove that goes around the middle. But I am not sure what the purpose is of the groove that goes up and down. I thought I might need to line up the screw with this opening, but I have tried every tooth around it and the screw still catches.
There is also a small bump out on the bottom of the coupling, but even if I line the bump with the groove, it still catches.
I have checked the new coupling against the old one and it appears to be a match. I also tried using the old screw and it catches as well.
What is the trick I am missing? If I can't get the screw past the threads, there is no way to get it to mate with the other side of the coupling to install it.
And one more question while I am at it. The coupling has two pins one is larger than the other. The bottom of the steering column has two openings that from the other forum posts, it sounds like are intended as the fail safe if the coupling fails. They seem to be the same size. Does it matter where these openings are aligned to the pins?
Thanks so much for any help,
Ben
I added three more pictures at the same link above. They show the old and new parts. I think I am good with the part. It is a Dennis Carpenter Reproductions part that I bought at the NPD warehouse. I am lucky to have good parts sources because I live in Charlotte.
Part number C5TZ-3A525-A and it is clearly marked as a 65 part. Plus it matches the one taken off. I guess it is possible that at some point the steering box or steering shaft were replaced, but I assumed since it was a match to the old one I was good.
I can easily thread the screw through the part when it is not on the truck. I can also easily put the part on the shaft when the screw is not in the part.
So for you.....you just put it on the shaft wherever it was most convenient? No consideration of the groove that runs up and down the shaft of the steering box?
Thanks,
Ben
NPD: Charlotte - Carpenter: Concord - Carolina Classics: Durham
1965/66 F100/250 2WD with manual steering. P/S was not available in 1965 F100/250's. 4WD's were not available with P/S until 1973.
C5TZ-3A525-A .. Steering Coupler-Larger pin is .41" O.D.
1965 F100/250 2WD - 1966 F100/250 2WD before serial number 900,001.
C6TZ-3A525-A .. Steering Coupler-Larger pin is .56" O.D.
1966 F100/250 2WD from serial number 900,001 / 1967/68 F100/250 2WD & F350.
Serial number is the last six digits of the VIN
It turns out that the part I purchased was bad. After numerous attempts to make it fit, I finally re-installed the bad part as a test and had none of the troubles that I was having with the new one. That made me examine the screw holes on the end that clamps to the steering box shaft and I realized that the angle was causing the screw to be directed into the shaft.
Took the part back to NPD along with the old one, they agreed right away it was defective and gave me a new one without any hassle. The new one went on without issue.
<O
</O
The only remaining questions I have is in regards to the flange at the end of the Steering Shaft. <O
</O
Bill, <O
</O
You provided the steering shaft flange openings and mine DO NOT match. My openings are ¾ of an inch and 1 inch wide. There is a good possibility that the shaft has been replaced. It also seems to be a little too short to fully reach the rag joint and so the joint is flexed to form the connection. <O
</O
Can you confirm if this is a later model steering shaft…perhaps intended for a power steering box and therefore a little shorter?<O
</O
Thanks again for the help from both of you and even more so all the other replies you have given, which have been a great help when researching and resolving other issues. <O
</O
Ben<O
</O
