Power steering help
Old Jun 28, 2015 | 02:06 PM
dustinsheeler717's Avatar
dustinsheeler717
Power steering help
Okay, so i was driving down the road. Turned around and all of sudden I have no power steering... The fluid is good and I actually just replaced this ps pump 2 months ago.. Also when I hit the brakes they kinda feel weird too like there not working fully or something... Any suggestions would be appreciated.. or should I just start tearing this ps pump off?
Old Jun 28, 2015 | 02:40 PM
dannyboy950's Avatar
dannyboy950
OMG not another one LOL Read I hate commi cars post about his adventure withthe PIFA power steering pump. More info on the pump is covered there than you probably really want to know.
Old Jun 28, 2015 | 02:46 PM
dustinsheeler717
Where can I read that at?
dustinsheeler717
Is the brakes tied in with the ps pump or something because my brakes Def don't want to stop like they normally do
Old Jun 28, 2015 | 03:05 PM
dannyboy950
On a 6.0 the brake assit[master cylinder] works in tandem with the power steering booster. The power steering booster actually pushes the Master cylinder rod. No vacum booster.
The thread is about 5 threads below yours.
Old Jun 28, 2015 | 07:06 PM
dustinsheeler717
I cant believe no one has not experienced anything like this. I have no power steering or power brakes. No whining noise from ps pump.. please anyone help!
Old Jun 28, 2015 | 07:28 PM
Yahiko's Avatar
Yahiko
Here are some PDF files. I'll look for the diagnostics one.
Found them before I posted this.
Sean
Old Jun 28, 2015 | 08:05 PM
dustinsheeler717
I've read over all the info you posted. Thank you. Yet I still have no idea what would be doing this. I guess I'll just have to replace the power steering pump again! And go from there
Old Jun 28, 2015 | 09:10 PM
TooManyToys.'s Avatar
TooManyToys.
We understand your frustration and I know I wish there was a quick and easy answer but there's not.
The rebuilt pump may have failed on its own. Or there may be debris from the old pump that took out the rebuilt pump, or maybe a hose, steering box, or hydrobooster issue that took out the new pump. If both steering and braking are diminished you have to look to the pump.
The way I would proceed would be to drain all the fluid I could into a container and then use a paint strainer to see if any debris are found. I would also install a filter as mentioned in the other thread in the line between the steering box and reservoir as a precautionary measure. Then install the new pump. Unless you are familiar enough on how to open the steering box and inspect it though the cover, and reinstall the cover and get the adjustment back EXACTLY the way it was, this is a trial and error task.
Hopefully it's just a bad rebuilt pump.
Old Jun 28, 2015 | 10:13 PM
Yahiko's Avatar
Yahiko
I think you have the best cost effective way. The only other way and the price goes up
would be to have a Power Steering Analyzer.
Sean
Old Jul 8, 2015 | 01:14 AM
dustinsheeler717
Okay I just like to follow up with everyone since you guys are always so much help. So I replaced the power steering pump with a reman from advanced auto with pully already installed just to find out the shaft was bent and all it did was make the belt squeak... So I decided to go to a junkyard and pull a used orginal ps pump off a 6.0 and things are better so far. So thanks guys.
Old Jul 8, 2015 | 03:14 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Amazing!!!
Old Jul 8, 2015 | 10:44 PM
xaviar's Avatar
xaviar
I can't even find a 6.0 in a salvage yard around here.
Kelpy1
Sep 10, 2016 06:40 PM
Big Sky
Nov 1, 2012 11:44 AM
Mathematicus
Mar 12, 2010 04:49 PM
60RatRod
Nov 26, 2008 06:59 PM
paulford
Aug 9, 2006 01:01 AM
