Power Steering Pump & Hydroboost
Old Oct 31, 2012 | 08:18 PM
Big Sky's Avatar
Big Sky
How are the power steering pump and hydroboost tied together? The reason I am asking is that my PS pump is making noise and my brakes don't feel as firm as they usually do. I am thinking of changing out the pump and flushing the system.
Old Oct 31, 2012 | 08:22 PM
BigAlsPSD's Avatar
BigAlsPSD
The power steering pump is where the hydroboost gets it's pressurized fluid.
Have you tried previously flushing, if not you might be surprised how well it might work.
Old Oct 31, 2012 | 08:30 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Yes like Alan said the powersteering pump provides the pressure to the the hydroboost system. When I did my flush my brakes got better too.
I have a video on how to do the flush procedure, and there are text-based write ups as well.
Old Oct 31, 2012 | 08:52 PM
Big Sky's Avatar
Big Sky
I did the flush this past summer and the brakes felt great. Just wondering if a whiny/failing PS pump might not generate enough pressure?
Old Nov 1, 2012 | 06:27 AM
Nsaan's Avatar
Nsaan
Yes it can, I just replaced my pump earlier this year, I also had a high pressure line leaking, now after getting it all fixed back up, it looks like my Hydrobooster has started leaking behind the master cylinder. It is always something with these trucks.
The powersteering pump pressure feeds to the Hydrobooster first, then the other high pressure line feeds down to the steering box, there are 2 low pressure return lines, one from the hydroboost and one from the steering box, both of those return to the pump reservoir. If you replace the pump make sure you replace the white nylon washer that is on the high pressure line, as that is what seals it. Just a tip, the high pressure line fittings will move some even when they are tight.
Old Nov 1, 2012 | 09:42 AM
kell104's Avatar
kell104
You could try flushing again if the fluid is really dark in color. Should be a nice bright cherry red like new tranny fluid. Is there a chance you got any air into the system? That could cause what you describe too. If the fluid is nice and clean and there is no air than you probably need a pump.
Old Nov 1, 2012 | 11:44 AM
SpringerPop's Avatar
SpringerPop
Pump whine will occur when the fluid level gets "only just a bit" low.
It doesn't take much to set off the noise, so be sure that's not your problem before replacing things.
Pop
dustinsheeler717
Jul 8, 2015 10:44 PM
F250racer
Feb 17, 2011 03:58 PM
Mathematicus
Mar 12, 2010 04:49 PM
dcassidy
Sep 17, 2009 09:11 PM
tomtoc
1983 - 2012 Ranger & B-Series
Feb 15, 2007 02:40 PM
