Power steering pump and brakes
99 psd. I noticed that the truck won't turn the tires from a stop. It whines and the tires move when the truck starts to move. On top of this the brakes seem a bit hard at times. Not always though
From what I read the power steering pump also drives the brake assist (is that right?).
Just checking fluids I noticed the power steering pump reservoir was a bit low. Would this cause the problems I am seeing or should I go ahead and just change the pump before I lose the brakes at the wrong time?
Truck has 252k miles and I don't know the maintenance history. . .
Thanks, Kelpy
Thanks, Kelpy
Originally Posted by Kelpy1
Holy smokes that's a lot of miles! I'm amazed that the pump has lasted that long.
I hope someone with knowledge drops by. I would like to know myself.
...or should I go ahead and just change the pump before I lose the brakes at the wrong time?
You can, there is even a video about it... I did this on mine and the fluid that had come out was not the color it should have been by any means.
How To: Power Steering Flush on 7.3L/6.0L Powerstroke (HydroBoost) - YouTube
brownie83
29
09-17-2010 07:22 PM
