'05 F150 Power Window Problem
Old Jun 25, 2015 | 06:03 PM
nagetech's Avatar
nagetech
Hello everyone! Hoping you guys can help me out with a problem in my GF's truck.
She has a 2005 F150 Lariat 4 Door.
Problem just started the other day where the only way she can roll down the Passenger Windows was from the driver side switch. All the other doors WILL NOT roll the windows down.
Originally, I had thought something happened with the master switch. I went ahead and replaced it, and of course that didn't work. I checked all the switches and cleaned them and no luck. I have noticed that the other 3 doors do not have the green illumination on the Power Window Switch.
I'm not sure why this is happening, so hoping you guys can help me out and give me some pointers! Help me be a hero to my gal
Let me know if there is any other info you need!
Old Jun 26, 2015 | 09:16 PM
F150Torqued's Avatar
F150Torqued
Post OPEN in the Lock Switch wire
@nagetech
You have given a good meaningful description of the problem.
Originally Posted by nagetech
... I have noticed that the other 3 doors do not have the green illumination on the Power Window Switch. ...
From the symptoms you describe I believe the wire from the "Lock Switch" is open somewhere between the switch and the other three doors.
I have temporarily placed Factory service manual pages from window section for your truck in a Public folder on my server - you should be able to download and print or save them.
www.devoll.com/Public/F150-window-wiring.pdf
www.devoll.com/Public/F150-windows.pdf
Check the "Yel/Lt Green" wire from pin 7 of the "Lock" button on the master switch to the Passenger door window switch, pin 4. You may have to cut open the rubber boot in the driver's door (most likely trouble spot) or the passenger door.
Hope this helps
Old Jun 27, 2015 | 09:46 AM
nagetech's Avatar
nagetech
Thank you so much for going out of your way for me!
In googling I found similar information regarding checking the boot. I will be looking at it this weekend and seeing if it is a broken wire.
Ill report back!
Old Jun 28, 2015 | 08:15 PM
nagetech's Avatar
nagetech
Just wanted to report back and thank you guys. I pulled the rubber boot on the driver door, and there she was! Broke wire Spliced her right up and BAM I was the hero! Excuse me while I go celebrate.
Old Jun 28, 2015 | 11:12 PM
F150Torqued
Thumbs up Success feels SO GOOD
Congratulations. You did good! And thanks for the report back.
quietman
Dec 12, 2018 11:53 AM
ugh3012
Jul 4, 2016 08:54 AM
tanktopsntoolbelts
Apr 30, 2012 07:52 PM
boogaloo
1978 - 1996 Big Bronco
Mar 6, 2011 12:35 PM
3vanman
Aerostar
Dec 21, 2003 04:55 PM
