Turbo malfunctioning when hot
Old Jul 1, 2015 | 11:00 AM
WatsonR's Avatar
WatsonR
EBP= exhaust back pressure
EOT= Engine oil temp
ECT= Engine coolant temp
MAP= Maniflod absolute pressure
The digital gauge you get should be able to read those items from the OBD II (on-board diagnostics) port on the truck. Those numbers in live time can help diagnose the issues your having.
Old Jul 1, 2015 | 11:02 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Check fuel PSI
Josh
Old Jul 1, 2015 | 11:03 AM
WatsonR's Avatar
WatsonR
some of those sensor help control how the turbo runs.
Old Jul 1, 2015 | 02:16 PM
Yahiko's Avatar
Yahiko
FTE Remembers
Is there not a list of all the crazy acronyms in the Tech Folder ?
While your waiting on the books/DVDs take time to look in the Tech Folder
at the info there. There are a lot of things that most of the Ford stuff does not
cover/approve/include. In some cases they replace a part where we may fix it.
Also if you get the Ford service manuals from Ebay that are the expired date
one (The best IMHO) then your want the little program called Run As Date.
Also there is a way to copied it all to your hard drive and have it run correctly.
If you go that route let me know and I can send you the info on how to edit
the INI file that controls it.
Sean
Old Jul 1, 2015 | 06:01 PM
DawnPatrol's Avatar
DawnPatrol
Hang in there Larry. As soon as you get the readouts from whatever scanning tool you get (I use the ScanGaugeII), there are some great experts on this panel.
Alan from San Diego
Old Aug 15, 2015 | 02:45 PM
matieenterprise's Avatar
matieenterprise
I was able to do the testing, finally, and this is what I found. Some of the questions that were asked, I was unable to find a reading for. I will post all the readings minus the throttle, that my phone and adapter showed using OBDII and Car Gauge Pro app.
Load was 99.6 just before the truck bogged down and it dropped to 91.6 when the truck started bogging down that the turbo psi dropped.
ECT was 179.6 and went up to 185.
Manifold was 187
Air temp was 100
Barometric psi was 102
Modular volts was 13.67 and dropped to 13.47 when truck bogged down
I checked the turbo and the blades/fan turns easy with very little play in it.
I tried to check everything listed above but I may have missed something.
The truck still runs fine when the engine is cold. Once the engine heats up, it starts bogging down still and throws black smoke out the exhaust at certain rpms.
Any ideas?
Larry
Bar B Q
Feb 27, 2015 06:36 PM
Bar B Q
Feb 22, 2015 06:34 PM
ironmike1970
Jul 25, 2013 10:05 PM
Hooker Bob
Sep 22, 2005 11:58 AM
TearDaClubUp
Feb 27, 2004 10:38 AM
