Turbo malfunctioning when hot
When the engine is cold, the truck runs fine but after driving for 15 minutes, I loose power in 3rd, 4th, and 5th gear. The gauge for the turbo drops from 20 down to 5 and the truck starts blowing black smoke. This starts at 1500 rpms and stops when I am past 2200 rpms. Before 1600 rpms and after 2200 rpms, the truck has lots of power but withing those ranges, the truck has almost no power at all. When I first got the truck, the problem didn't start until I was up to 1800 rpms.
No codes showing up either. I had the truck serviced by a diesel mechanic and the filters replaced using Ford parts. Problem persists and only exists when the engine is warm.
If it helps, I live in Beaufort, SC.
Any suggestions?
Larry
There is a gauge on the dash that shows the turbo psi which is where I got the reading from.
Sorry, I was wrong on the code reader. It was my car I was fixing when I used the reader, not my truck.
Big difference, I know but when I get migraines, I mix facts up sometimes.
Sorry for the mis-information.
A diesel mechanic used his laptop looking reader on the truck and found no codes.
Last edited by matieenterprise; Jun 25, 2015 at 05:47 PM. Reason: Correcting myself
https://www.ford-trucks.com/forums/1...eral-info.html
I would do as Rusty stated above, check the turbo.
Not sure if I would trust the scanner your dad has for scanning for codes, it may not be picking up Fords codes. A lot of them don't.
I tried running the scan for ford and it quit saying I needed the obdlink mx installed and I do not see one on play store.
I did try the gauges on the car gauge pro app but there are many to choose from and I do not know the names of all these things it lists so I do not know what gauges to put on the phone.
I did end up taking my truck back to a shop where the tech looked at it and found a sensor out of wack and changed it but the problem still exists. I got my truck back at no charge. I was also told that the intake and turbo needs replaced to fix the problem. From what he says, the turbo, at 1500 rpm's - 2200 rpm's in 3rd 4th and 5th gear, starts throwing too much air and opens some valve which in turn shuts down the turbo.
I do not know diesel and do not understand this but this is the info I have found and what I was told.
The tech said a friend of his had a truck doing the same thing that mine is and when he changed the intake and turbo the problem went away.
I cannot afford to put it back in the shop so I am driving it as is. I will try to find a service manual for the truck so I can at least see what I am doing on the truck.
Any advice or extra comments?
Larry
More you should find a new shop. It sounds like this guy is trying
to baffle you with bull****. That or he is smoking some very good stuff
and wants your $ to pay for more of it.
There are no sensors on the turbo. On the intake is a MAP port and a IA2
MAP = Manifold Air Pressure, IA2 = Intake Air (temp)2.
EDIT :
Two things that may be worth trying. Remove the MAP nipple and line
and see if it clear or plugged up. Same for the EBP sensor. once they
are know to be clean then you can go on to other things. BTW be careful
with the plastic nipples. They get brittle and break.
I sense starting from a blank point I would start with base oil pressure.
Do not use the dash gauge set it's useless. Get the Torque app or go get
something like the Scanguage 2 both are easy to use and everyone knows
what they are looking at when it comes to the numbers.
You need to know what the MAP,EBP,EOT,ECT are reading to start with when it's
warmed up and acting up on you.
Without that info there is not a lot anyone can do other than guess and cost money
by throwing parts at it.
Sean
I don't know what all these abbreviations stand for so I am having a difficult time following your instructions or finding these parts on my truck.
I have found and ordered service manuals for my truck so I can get a better understanding of what you are saying. I have googled these abbreviations and some are coming up blank and youtube isn't much better.
I should get these manuals in around Wednesday 7/08/2015. I appreciate all this advise but you may as well be speaking greek or mandarin as I have no clue what you mean.
I find, even in my line of work, I use abbreviations and terminologies without thinking as it is what I know and I have to back up and explain to my customers what I mean. I still get a blank look at times. Now I know what they must feel like when i talk to them.
I think I found the turbo but the pictures I find online shows the turbo but not on a truck like mine so I am not certain. I don't mind tearing things apart or delving into new things but without a bit of understanding as to what does what and what not to mess with, I am cautious. I don't need to break something by accident because I grab, twist or try to disconnect the wrong thing. Perhaps even this statement shows my ignorance when it comes to diesels.
Please be patient, I will get busy as soon as I get these books and thanks for your time.
Larry
