Can somebody snap a pic of the alternator and bracket set-up that would be found on a '75 360 engine? I am trying to figure out if I have the correct pieces but cannot find a great pic online of what I am looking for.
I purchased my truck with the engine compartment in shambles. The alternator was off and the brackets were laying on an inner fender. the brackets I have seem to mount the pivot point of the alternator at the top and leave the arched adjustment bracket at the bottom for a low mount. Mine may not be the factory set-up for my application I guess. I'll try to post a pic later. thanks for your help, Mike. Those are good photos.
Here is what I came up with using the brackets that came with the truck. Is this a standard truck mount location given there is no AC compressor? Not sure how close the inner fender will be when it is reinstalled. The pulley looks to be aligned with the crank and water pump pulleys.
