Cold startup great, warm startup difficult
Old Jun 12, 2015 | 07:34 AM
mikerogers56's Avatar
mikerogers56
When I start my truck after it's been sitting overnight or for a long period of time it will start right up when I turn the key. If I've been driving it and turn it off to run in a store or something I have to pump the hell out of the gas and let the starter turn over and over and hope and pray it fires up. It always starts but I've come close to draining the battery a few times. Any thoughts?
Old Jun 12, 2015 | 08:02 AM
6.2 V8 power's Avatar
6.2 V8 power
What year is your truck? Gas or diesel?
Do a load test on the battery when the motor is hot. Auto Zone or a auto parts should do this for free.
Old Jun 12, 2015 | 08:37 AM
mikerogers56
78 302 auto ps pb
Old Jun 12, 2015 | 06:08 PM
Blue and White's Avatar
Blue and White
A common problem is heat soak which boils the gas out of the carb. Quite a bit winds up in the intake so its flooded and not enough gas in the bowl.
For warm re-start I generally hold the throttle about 1/3 open... don't pump it. That will get some fresh air going through the intake and help it get started.
If the fuel pump and fuel line is really heat soaked, it may temporarily vapor lock also. Adding an aft mounted electric pump can help with this. Hot re-start on mine seems a little better after adding the electric.
yewdall
Dec 8, 2021 08:30 AM
RevLemmon
Jan 2, 2016 05:18 PM
jake_whitman
Dec 21, 2014 10:36 PM
02GrayPowerStroke
1997 - 2003 F150
Jul 30, 2014 06:56 PM
yankeerebel
24
Oct 17, 2009 01:01 AM
